Lpc2000
AW: [lpc2000] CAN DOIE
2005-09-15 by Gromann, Klaus
Hi Fredrik,
there are 2 things in your code that may cause problems :
1) You don't read the frame status register(CANRFS), so you loose the information if it is a 11-bit or a 29 bit identifier as well as the data length information and the remote request bit.
2) It is written in the comment but not done : release the buffer. To do this, you have to write 1 to bit2 in the command register (CANCMR)
brgds
Klaus
-----Ursprüngliche Nachricht-----
Von: lpc2000@yahoogroups.com im Auftrag von albin_martinsson
Gesendet: Do 15.09.2005 15:35
An: lpc2000@yahoogroups.com
Betreff: [lpc2000] CAN DOIE
Hello
Im using the CAN-interface in my application.
My routine for CAN is interrupt-driven, here is an example of my ISR-
code:
I often get Data Overrun - error on the receive channel.
Anyone who has had the same problem?
I also use the freeRTOS port for the LPC2129.
B.R
Fredrik Martinsson, Sweden
void ISR_CANRX (void)
   tU32 *cBufdst;
   tU32 Buf[3];
   while (C1GSR&0x01) {
      // Save registers temp.
      Buf[0] = C1RID;
      Buf[1] = C1RDA;
      Buf[2] = C1RDB;
      C1CMR = 0x04;
      // release receive buffer
      if (++can_rxbufin>=CAN_QUEUESIZE)can_rxbufin = 0;
      cBufdst = &can_rxbuf[can_rxbufin].CmRID;
      if (can_rxbufin == can_rxbufout) {
         if (++can_rxbufout>=CAN_QUEUESIZE)can_rxbufout = 0;
      if (++can_rxbufsize>CAN_QUEUESIZE)
can_rxbufsize=CAN_QUEUESIZE;
      *cBufdst = Buf[0];
      cBufdst++;
      *cBufdst = Buf[1];
      cBufdst++;
      *cBufdst = Buf[2];
      // Give semaphore to start comTask
      xSemaphoreGiveFromISR( comSem, pdFALSE );
   VICVectAddr = 0xFFFFFFFFL;
   // acknowledge Interrupt
SPONSORED LINKS
Microprocessor <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>  	Microcontrollers <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>  	Pic microcontrollers <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
8051 microprocessor <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
YAHOO! GROUPS LINKS
	*	 Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000> " on the web.
*	 To unsubscribe from this group, send an email to:
	 lpc2000-unsubscribe@yahoogroups.com <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Hi Frederik,
sorry, I've overseen the line with the request. So this cannot be the problem.
Is it possible that the IRQ is disabled for a longer time period ?
I use the CAN on LPC2294 now for about 8 weeks and got no problems.
brgds
Klaus
Von: lpc2000@yahoogroups.com im Auftrag von Gromann, Klaus {GGRH~Graz}
Gesendet: Do 15.09.2005 16:16
Betreff: AW: [lpc2000] CAN DOIE
Hi Fredrik,
brgds
Klaus
Hello
code:
B.R
   tU32 *cBufdst;
   tU32 Buf[3];
      Buf[0] = C1RID;
      Buf[1] = C1RDA;
      Buf[2] = C1RDB;
      C1CMR = 0x04;
      *cBufdst = Buf[0];
      cBufdst++;
      *cBufdst = Buf[1];
      cBufdst++;
      *cBufdst = Buf[2];
SPONSORED LINKS
YAHOO! GROUPS LINKS
SPONSORED LINKS
YAHOO! GROUPS LINKS
Re: CAN DOIE
2005-09-16 by albin_martinsson
Hi Klaus,
The thing is that I really dont know if the IRQ is disabled for a
longer time, im using the freeRTOS port for LPC2129 so. If anyone
here knows, your can pleas tell me, or I will start to have a look
inside the code for the freeRTOS.
BTW Klaus, in your system, how many systems are talking on the same
bus? Im using 3 units talking and the Bus Load not greater than 20-
30%.
B.R
/Fredrik
--- In lpc2000@yahoogroups.com, "Gromann, Klaus"
<klaus.gromann@r...> wrote:
> Hi Frederik,
the problem.
> brgds
> Klaus
{GGRH~Graz}
> Hi Fredrik,
(CANCMR)
> brgds
> Klaus
> Hello
ISR-
> code:
> B.R
>    tU32 *cBufdst;
>    tU32 Buf[3];
>       Buf[0] = C1RID;
>       Buf[1] = C1RDA;
>       Buf[2] = C1RDB;
>       C1CMR = 0x04;
>       *cBufdst = Buf[0];
>       cBufdst++;
>       *cBufdst = Buf[1];
>       cBufdst++;
>       *cBufdst = Buf[2];
> SPONSORED LINKS
7c6LyBvUqVQ>
VIlekkDP-A>
> YAHOO! GROUPS LINKS
> SPONSORED LINKS
7c6LyBvUqVQ>
VIlekkDP-A>
> YAHOO! GROUPS LINKS
