Lpc2000
RS485
RS485
2005-09-19 by gfaurie1
Hello,
I try to develop a RS485 driver, but i have a problem.
As you know, you must stay in reception and when you have to transmit,
you change direction to be in transmission only during transmission.
When the last character has been transmitted you turn back in
reception.
Problem is that i have no interruption on shift register empty. I have
an interruption when transmitter is empty but if i change direction at
this time, character which is in shift register is not transmitted,
and i lose it.
The only solution that i suppose is to check state of shist register
(LSR) in polling but i'd like to find a more real time solution
Who can help me ?
Thank
Re: RS485
2005-09-19 by Grzegorz
one of the possible solution is to start timer on transmitter empty
event, initiated with a bit duration times bitframe length value
(typical x10..11). During timer reload event you can simply switch
RS485 line to rx mode.
I use this scenario in my design with no problem.
Grzegorz
--- In lpc2000@yahoogroups.com, "gfaurie1" <gilles.faurie@p...> wrote:
> Hello,
transmit,
transmission.
> reception.
have
at
> and i lose it.
register
> Who can help me ?
> Thank
RE: [lpc2000] RS485
2005-09-19 by Yves Rondeau
Hello ,
I had the same problem on ISO7816 communication.
At the end of TX I switch back in input mode then lost the 2 last bytes.
Add those lines at the end of your TX routines
while (!(U1LSR & 0x40));   /* Wait if U1THR & U1TSR not empty */
  				   /* we need to wait for the 2 Tx Buffer */
				   /* to be empty	*/
			 	   /* or we can lost the 2 bytes switching
				   /* in input */
  PINSEL0 = 0x00040000;	   /* RX UART1	Enable -TX Disable	*/
Yves
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf Of
gfaurie1
Sent: segunda-feira, 19 de Setembro de 2005 7:44
To: lpc2000@yahoogroups.com
Subject: [lpc2000] RS485
Hello,
reception.
and i lose it.
Who can help me ?
Thank
Yahoo! Groups Links
Re: [lpc2000] RS485
2005-09-19 by Gilles FAURIE
Yes i could do that but i don't want to wait in my interruption routine
during character transmission which could be about 1ms (at 9600 baud).
To: <lpc2000@yahoogroups.com>
Sent: Monday, September 19, 2005 11:17 AM
Subject: RE: [lpc2000] RS485
> Hello ,
>    /* to be empty */
>    /* in input */
> Yves
> Of
> gfaurie1
> Hello,
> reception.
> and i lose it.
> Who can help me ?
> Thank
Re: [lpc2000] RS485
2005-09-19 by Peter Jakacki
Gilles,
If you don't disable the 485 receiver or the UART rx itself you can
monitor the bytes that are transmitted. There are variations on this
scheme but it means that you could simply turn off the 485 transmitter
when you receive the last character that you transmitted.
Also, as Grzegorz pointed out you could use a timer, that is if you have
one to spare.
Both of these are practical real-time solutions and easily implemented.
BTW, Yves sample code seems to be switching the PINSELs which has got to
be totally redundant and unnecessary. Just keep the rx and tx alive and
you only need to drive the 485's TE pin.
>----- Original Message -----
>From: "Yves Rondeau" <op173039@...>
>>Hello ,
>>   /* to be empty */
>>   /* in input */
>>Yves
>>-----Original Message-----
>>Of
>>gfaurie1
>>Hello,
>>reception.
>>and i lose it.
>>Who can help me ?
>>Thank
Re: [lpc2000] RS485
2005-09-19 by Bill Knight
Another option is to send a trailing NULL (0x00) character and allow it
to be the character that is dropped.
-Bill Knight
R O SoftWare &
http://www.theARMPatch.com
On Mon, 19 Sep 2005 06:44:10 -0000, gfaurie1 wrote:
>Hello,
>reception.
>and i lose it.
>Who can help me ?
>Thank
>Yahoo! Groups Links
Re: [lpc2000] RS485
2005-09-19 by Sebastien Jacquemard
I've the same pb few month aog. I do this and it's work fine. I hope this
exemple help you.
#define EN_TXD1  0x00010000
#define EN_RXD1  0x00040000
#define SENS  0x00000400 //P0.10 = Rs485 sens
#define Txd         1       // RS485 : mode transmission
#define Rxd         0       // RS485 : mode r\ufffdception
#define TXD_BREAK 0x40 // Set TXD break
void init_rs485()
 IOSET0=SENS; //SENS=TXD
 PINSEL0 |= EN_RXD1 | EN_TXD1;          // Enable RxD1 and TxD1
   U1LCR = 0x8B;                          // 8 bits, Odd parity, 1 Stop bit
   U1DLL = Baud187500;
   U1LCR &= 0x7F;                         // DLAB = 0
void trasnmit_rs485(uchar *p)
 uchar n;
 uchar pause;
 IOSET0=SENS; //SENS=Txd --> rs485 in tx mode
 U1LCR|=TXD_BREAK; //break on txd1 line
 tempo(110); //tempo 90usec
 U1LCR&=~TXD_BREAK; //clear break
 n=*p++;
 do{
  while (!(U1LSR & 0x20)) watchdog(); //wait tx buffer empty
  U1THR = *p++;
 } while (--n);
 //wait buffer empty before swith in rx mode
 while ((U1LSR & 0x60)!=0x60) watchdog();
 IOCLR0=SENS; //SENS=Rxd --> rs485 in rx mode}
uchar receive_rs485(uchar *p)
 uchar n;
 uint fin;
 n=*p;    // number of char to receive
 fin=100000;
 do{
  do{
   if (!fin)
    return(0);
   fin--;
   watchdog();
  } while(!(U1LSR & 0x01)); //wait char
  *p++=U1RBR;   // store char
 } while(--n);
 return(1);
Re: [lpc2000] RS485
2005-09-21 by Gilles FAURIE
Thanks everybody,
I used solution with timer. I have 2 serial link with two RS485 possible. So
i use timer 1 with two Match Register (MR0 and MR1).
Fisrt I calculate time for one character tranmssion  (TimeCar). When my
transmitter is empty i program MR with the value TC + TimeCar and i activate
IT timer.
In the IT timer i turn back in reception.
void TIMER1_irq ()
  // Test du registre MR0 du timer1
  if ((T1IR & 0x01)==0x01)
    T1IR |= 0x01;
    if ((T1MCR & 0x01) == 0x01)
    {// MR0 activé et actif
      T1MCR &= ~0x01;
     // On descend RTS
     vTransmissionRs485(0, OFF);
  // Test du registre MR1 du timer1
  if ((T1IR & 0x02)==0x02)
    T1IR |= 0x02;
    if ((T1MCR & 0x08) == 0x08)
    {// MR1 activé et actif
      if ((U1LSR & 0x40) != 0x40)
        GEN_TraitErreur();
      T1MCR &= ~0x08;
      // On descend RTS
     vTransmissionRs485(1, OFF);
/* Only a part of my UART IRQ to not lose you */
      if (pSer->bRs485 != FALSE)
        if ((*(pbReg + OFF_LSR) & 0x60) == 0x20)
        {// If THR Empty and Shift register not empty
          // We activate timer
          *pSer->MR = T1TC+pSer->dMatchReg;
          T1MCR |= pSer->bValItTimer;
        else
          if ((*(pbReg + OFF_LSR) & 0x60) == 0x60)
           vTransmissionRs485(1, OFF);// No more transmission
Sent: Monday, September 19, 2005 3:29 PM
Subject: Re: [lpc2000] RS485
> Gilles,
> one to spare.
>>>Hello ,
>>>   /* to be empty */
>>>   /* in input */
>>>Yves
>>>Of
>>>gfaurie1
>>>Hello,
>>>reception.
>>>and i lose it.
>>>Who can help me ?
>>>Thank
RE: [lpc2000] RS485
2005-09-21 by Lasse Madsen
Philips should be ashamed of them selves making such an obsolete uart...
Let's all complain and hope that they will change it in future chips...
Lasse Madsen
Re: RS485
2005-09-21 by Karl Olsen
--- In lpc2000@yahoogroups.com, "Lasse Madsen" <Lasse.Madsen@E...>
> uart... Let's all complain and hope that they will change it in
> future chips...
I tend to agree.  They did add some handshake and baud rate generator
features in LPC214x, but nothing to handle the age-old RS485
transmitter problem. Atm*l has always had a much more capable UART.
Karl Olsen
