AW: [lpc2000] uc/OS II Problem
2005-09-20 by Huber Martin
Hi difficult to help you. What Port of uC/OS do you use? J.J.Labrosse's one? Give us more information to help you. I use uC/OS too, and it works great. I took the port from J.J.Labrosse himself. Best regards Martin ________________________________ Von: swanann2000 [mailto:swanann2000@...] Gesendet: Montag, 5. September 2005 20:12 An: lpc2000@yahoogroups.com Betreff: [lpc2000] uc/OS II Problem Hi! For a dummy application with lpc2138 I'm using uc/OS II. I make 2 tasks (LED ON / LED OFF) with a time delay of 10. The sched change the task enviroment correctly between the two taks, but after the time delay (from 2 tasks) the program stay at the IdleTask routine forever because there isn't a Os_sched()call. I have been looking for a lot of documentation but nothing appears. What is the correct procedure to work with uc/OS II?, I need to create a timer interrupt (TMR1), TMR0 is the timestick() call, that calls continuosly the Os_sched()? Thanks a lot! ________________________________ YAHOO! GROUPS LINKS * Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000> " on the web. * To unsubscribe from this group, send an email to: lpc2000-unsubscribe@yahoogroups.com <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . ________________________________ [Non-text portions of this message have been removed]
