Cute TFT/OLED/LCD colour Screen recommendation?
2005-09-22 by donwillwonthe
Can anyone recommend a neat little approx 4cmX5cm or bigger colour display/screen I could use for my instrument project ??? Something that doesnt use too much NV memeory or RAM on the microcontroller, is well priced and easily driven?
2005-09-23 by valdef78
--- In lpc2000@yahoogroups.com, "donwillwonthe" <donw@c...> wrote: > Can anyone recommend a neat little approx 4cmX5cm or bigger colour > display/screen I could use for my instrument project ??? Something > that doesnt use too much NV memeory or RAM on the microcontroller, is > well priced and easily driven? maybe you should look at phone lcd from Nokia for exemple. like the "standard" 3310 (there are many infos on it on the web). that a simple B&W lcd with SPI interface. for a bigger one in color, maybe the 6100 (see here for exemple : http://www.apetech.de/article.php? artId=3&nnId=12).
--- In lpc2000@yahoogroups.com, "valdef78" <valdef@s...> wrote: > --- In lpc2000@yahoogroups.com, "donwillwonthe" <donw@c...> wrote: > > Can anyone recommend a neat little approx 4cmX5cm or bigger colour > > display/screen I could use for my instrument project ??? Something > > that doesnt use too much NV memeory or RAM on the microcontroller, > is > > well priced and easily driven? > > maybe you should look at phone lcd from Nokia for exemple. like > the "standard" 3310 (there are many infos on it on the web). that a > simple B&W lcd with SPI interface. for a bigger one in color, maybe > the 6100 (see here for exemple : http://www.apetech.de/article.php? > artId=3&nnId=12). complete link for the 6100 : http://www.apetech.de/article.php?artId=3&nnId=12 that's a Deutch webpage, but you could see the good infos easily to have a idea of it. 132x132x4096 colors..
2005-09-23 by dsidlauskas1
Does anyone now of a source of technical information (in English) for these types of devices? Specifications, interface details, both software and hardware, etc. Thanks, Dave S. --- In lpc2000@yahoogroups.com, "valdef78" <valdef@s...> wrote:
2005-09-23 by Mike
--- In lpc2000@yahoogroups.com, "dsidlauskas1" <dsidlauskas@w...> wrote: > Does anyone now of a source of technical information (in English) for > these types of devices? Specifications, interface details, both > software and hardware, etc. > > Thanks, > > Dave S. A good place to start is probably: http://forum.lcdinfo.com/viewtopic.php?t=586 It does look a good item to use, built in controller, proper LCD, decent resolution and most importantly, cheap! Mike
2005-09-23 by Boris Estudiez
23/09/2005 - 12:20 Maybe you could download the LCD controller datasheet for more information: For Nokia 3310: http://www.amontec.com/lcd_controller_pcd8544.pdf http://www.amontec.com/lcd_nokia_3310.shtml For Nokia 6100: http://www.semiconductors.philips.com/pip/PCF8833U.html http://www.semiconductors.philips.com/acrobat/datasheets/PCF8833_1.pdf See also: http://www.display3000.com/html/english.html http://www.display3000.com/html/screen-shots.html http://www.shop-en.display3000.com/ Kind Regards, Boris Estudiez.- On 23/09/2005 at 14:36:27 -0000 dsidlauskas1 Wrote: > Does anyone now of a source of technical information (in English) for > these types of devices? Specifications, interface details, both > software and hardware, etc. > > Thanks, > > Dave S. > > > --- In lpc2000@yahoogroups.com, "valdef78" <valdef@s...> wrote: > > --- In lpc2000@yahoogroups.com, "donwillwonthe" <donw@c...> wrote: > > > Can anyone recommend a neat little approx 4cmX5cm or bigger colour > > > display/screen I could use for my instrument project ??? Something > > > that doesnt use too much NV memeory or RAM on the microcontroller, > > is > > > well priced and easily driven? > > > > maybe you should look at phone lcd from Nokia for exemple. like > > the "standard" 3310 (there are many infos on it on the web). that a > > simple B&W lcd with SPI interface. for a bigger one in color, maybe > > the 6100 (see here for exemple : http://www.apetech.de/article.php? > > artId=3&nnId=12). > > > > > > > > Yahoo! Groups Links > > > > > -- Contacteme en: * Mail(1): stk@... * Mail(2): 43824@... * Mail(3): slicetex@... * Website: http://stk.freeshell.org EOF
2005-09-23 by bkmohlman@jlg.com
To anyone,
Where can you get the philips controller based displays from???
Brian K. Mohlman
Project Engineer (Electrical)
Advanced Concepts Design Engineering
JLG Industries Inc.
1 JLG Drive
McConnellsburg, PA 17233
Ph. (717) 485-6495
mailto:bkmohlman@...
http://www.jlg.com
http://www.gradall.com
The information contained in this transmission is confidential. It is
intended solely for the use of the individual(s) or organization(s) to
whom it is addressed. Any disclosure, copying or further distribution
is not permitted unless such privilege is explicitly granted in writing
by JLG Industries, Inc.
Further, JLG Industries, Inc. is not responsible for the proper and
complete transmission of the substance of this communication nor for
any delay in its receipt.2005-09-23 by skymab
Does anyone know the dimension of the display? I am searching for a similar display but I mustn't be larger than 45mm in height.
2005-09-23 by Sebastien Jacquemard
The viewing dimension is nearly 28x28mm mechanical : height : 46mm with connector , width : 35mm, 4mm thickness you can buy them here : www.display3000.com for 18,50 euros, they send with all the technical doc + a library in basic sebastien ----- Original Message -----
From: "skymab" <skymab@...> To: <lpc2000@yahoogroups.com> Sent: Friday, September 23, 2005 7:24 PM Subject: [lpc2000] Re: Cute TFT/OLED/LCD colour Screen recommendation? > Does anyone know the dimension of the display? > I am searching for a similar display but I mustn't be larger than 45mm > in height. > > > > > > > > > Yahoo! Groups Links > > > > > > > >
2005-09-24 by Mike
--- In lpc2000@yahoogroups.com, bkmohlman@j... wrote: > > To anyone, > > Where can you get the philips controller based displays from??? First stop is your local mobile phone repair shop. They should have a selection of screens for various models, and you should be able to select an appropriate one (assuming you can physically see the chip). Second option is Ebay. There are hundreds of replacement LCDs for sale, I'm sure at least one of them would be able to sell you an appropriate one. http://cell-phones.listings.ebay.com/Accessories-Parts_LCD-Screens_W0QQfromZR4QQsacatZ50330QQsocmdZListingItemList Mike.
