Lpc2000
lpcisp program
lpcisp program
2005-09-30 by Stefano Coluccini
Hi all,
   I'm using part of the lpc21isp to program lpc2106 and I've found that
there is a problem with binary images larger that 64k. I'm using Keil
uVision 3 and hex files. I've seen that hex file contains record type 04
to jump the 64k limit of the adresses. With the follow change it works
for me:
             else if(RecordType == 0x04)     // 04 - Extended linear
address record, used by IAR
                 unsigned long app;
                 app  = Ascii2Hex(FileContent[Pos++]);
                 app <<= 4;
                 app <<= 4;
                 app <<= 4;
                 app <<= 16;
                 RealAddress |= app;
                 DebugPrintf( 1, "RecordType %02X: New RealAddress =
%08X\n", RecordType, RealAddress);
I hope this can help other users.
Stefano.
Re: [lpc2000] lpcisp program
2005-10-01 by Rob Jansen
Indeed,
the lpc21isp program does (or did? I've got a 1.28 version) use the
extended linear address record.
As Stefano did I also changed to code a bit to suit my needs.
On http://www.myvoice.nl/electronics/ there is a version of the program
that also allows programs to be written to RAM and executed from there
(a Go command is performed if a start linear address record is found).
The program looks at the first data received to determine if downloading
should take place to RAM or if a Flash write is in order.
It works for me (gnuarm with a slight modified version of the build
environment from EmbeddedArtists), should work for others as well.
Rob
> Hi all,
> for me:
2005-10-01 by Martin Maurer
Hello,
which version have you tried and found this bug ?
        Martin
To: <lpc2000@yahoogroups.com>
Sent: Friday, September 30, 2005 12:33 PM
Subject: [lpc2000] lpcisp program
> Hi all,
> for me:
>                 unsigned long app;
>                 app <<= 4;
>                 app <<= 4;
>                 app <<= 4;
>                 app <<= 16;
>                 RealAddress |= app;
> Cheers,
> Stefano.
Hello,
there is a yahoo group lpc21isp for a few month new about the lpc21isp.
Can you merge in your changes to 1.28 and upload this as new version to the
file area.
This is the central place for new development.
Regards and thanks,
          Martin
Sent: Saturday, October 01, 2005 8:40 AM
Subject: Re: [lpc2000] lpcisp program
> Indeed,
> Rob
>> Hi all,
>> for me:
2005-10-03 by Stefano Coluccini
Hi Martin,
   I use an old version but I verified that also the 1.27 does not
implement the 0x04 record type (it is not a bug, only not implemented
record type).
Bye,
Stefano.
Martin Maurer wrote:
> Hello,
> Regards,
>         Martin
> From: "Stefano Coluccini" <s.coluccini@...>
>> Hi all,
>> for me:
>>                 unsigned long app;
>>                 app <<= 4;
>>                 app <<= 4;
>>                 app <<= 4;
>>                 app <<= 16;
>>                 RealAddress |= app;
>> Cheers,
>> Stefano.
>> Yahoo! Groups Links
2005-10-03 by Martin Maurer
Hello Stefano,
can you try with latest version 1.29 ? You get it in the file area of
http://groups.yahoo.com/group/lpc21isp/
Two days ago, this was implemented (with a few other things) by Rob Jansen
(see his message in message section of lpc21isp group).
         Martin
Sent: Monday, October 03, 2005 10:19 AM
> Hi Martin,
> record type).
> Bye,
> Stefano.
>> Hello,
>> Regards,
>>         Martin
>> ----- Original Message -----
>>> Hi all,
>>> for me:
>>>                 unsigned long app;
>>>                 app <<= 4;
>>>                 app <<= 4;
>>>                 app <<= 4;
>>>                 app <<= 16;
>>>                 RealAddress |= app;
>>> Cheers,
>>> Stefano.
>>> Yahoo! Groups Links
>> Yahoo! Groups Links
2005-10-03 by Rob Jansen
Stefano,
Indeed, not a bug but a missing feature.
type 04
As Martin suggested, grab the 1.29 version from the lpc21isp yahoo group.
A compiled windo(w)s version is available from my website
    Rob
Thanks Rob, but in your website I have found only 1.28 precompiled and
1.29 in source. I'll try to compile 1.29 myself.
1.28 says to me:
"Use of multiple Extended linear address records [05] not supported"
Stefano.
Rob Jansen wrote:
> Stefano,
> type 04
> Regards,
>     Rob
Two things:
- in the 1.29 version there is still defined 1.28 as string version so
the program prints 1.28 instead of 1.29.
- my hex file still does not work. Error is:
However the same file works with Philips program and with the patch that
I posted.
Stefano.
Rob Jansen wrote:
> Stefano,
> type 04
> Regards,
>     Rob
Hello Stefano,
can you please merge in your change into version 1.29 and upload it as
version 1.30 ?
Please put a remark in version history and update version in two places (one
at beginning of file and once in line 121).
           Martin
Sent: Monday, October 03, 2005 3:00 PM
> Two things:
> I posted.
> Cheers,
> Stefano.
> Rob Jansen wrote:
>> Stefano,
>> type 04
>> Regards,
>>     Rob
Stefano,
>  'Use of multiple Extended linear address records [05] not supported';
First one is my fault, I'll fix this.
For the second problem; this is a feature, not a bug ;-). Could you send
me a hex file I could try (please not via te mailing list but use my
direct email address, does not has to be a working program).
I'll fix both and post the update on the
http://groups.yahoo.com/group/lpc21isp/ group (register with that group
and you'll be automagically informed on the update).
    Rob
