Problems using Insight with Wiggler
2005-10-03 by a1_eddy_arm
Hello all, I´m trying to get debugging work. I built a Wiggler HW according to the schematica on this site. I´m using a board with an LPC2106 (Elektor). I have no problem connecting at speed 1 (probably because the PC I´m using is a bit slow). I´m able to start downloading the *.elf file. Normaly the fist download fails, the second one seems to bee ok - but after the fist debugging step it crashes. When I download everything a third time. Then I´m able to step into C- Main. But simply start and waiting to break at the Breakpoint in Main also fails after the third download. I´m using the WinArm environment. Can anybody tell me what I´m doing wrong? Is there an other free debugging tool like Insight/gdb which works more reliant. Greetings, Eddy
