Lpc2000
OT: 4 layer PCB
OT: 4 layer PCB
2005-10-03 by fredrikssonjohan
Hi!
Well, this is off topic from LPC's but here we go...
As my boards get more and more crowded I want to look at 4 layer PCBs
instead of my usual 2 layer ones. What I can't find is some good info
and tutorials of best practice and what you shall think of designing
a 4 layer card.
I guess (and hope) that some here in the group does 4 layer cards and
can point me somewhere or give a tip or two :-)
Looking forward to any input on the subject!
Cheers
/Johan
Re: [lpc2000] OT: 4 layer PCB
2005-10-03 by DaedalWorks
A quick rule of thumb for a 4 layer PCB, is to use the inner layers for
power and ground planes.  Don't route any signals on the inner layers,
keeping the planes as connected as possible.  If you have multiple power
buses, you may be able to split the power plane, but be careful about
routing signals on the adjacent layer that cross the gap between the
planes.  This goes the same for the ground plane; avoid routing signals
across a gap in the plane.  These last two rules are more important at
frequencies higher than you're likely to encounter on an LPC, but it's
good to get into the habit, and certainly doesn't hurt (and you'll have
fewer bad habits to unlearn when you start playing with gigabit Ethernet ;-)
Hope that helps...
--DLM
fredrikssonjohan wrote:
> Hi!
> a 4 layer card.
> Cheers
> /Johan
2005-10-03 by Boris Králik
Hi.
Try to find book 'Analog-Digital Conversion' from
AnalogDevices, in this are all essential subject of
what you need and more and more.
Section 9.2: PC Board design issues.
I think, it find at AD website, but I did not try to
find it, I have book from AD seminar.
Full index: 'Analog-Digital conversion, Walt Kester,
March 2004,'
Boris.
--- fredrikssonjohan <johan@...> wrote:
> Hi!
> is some good info
> think of designing
> a 4 layer card.
> 4 layer cards and
> Cheers
> /Johan
Regards / S pozdravom Boris Kralik
http://www.geocities.com/kralikbo/
___________________________________________________________
To help you stay safe and secure online, we've developed the all new Yahoo! Security Centre. http://uk.security.yahoo.com
RE: [lpc2000] OT: 4 layer PCB
2005-10-04 by Lars Marmsater
Johan, your PCB layout system should almost force you in the right
direction. We use PADS (we are just starting up a four layer board design),
and the first thing you do is to define the two inner layers. The most
common approach is to use one inner plane for ground and one for power, most
likely 3.3V. You identify the net names (GND and VCC) for the planes to the
CAD system, and then it will take care of making the plane connections for
you. You can also route on the inner layers if you want to, but it is
usually a good idea to have at least one plane reserved for ground.
http://www.mentor.com/products/pcb/pads/index.cfm is a good starting point.
Lars
Sent: Monday, October 03, 2005 5:07 AM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] OT: 4 layer PCB
Hi!
a 4 layer card.
Cheers
/Johan
Yahoo! Groups Links
Checked by AVG Anti-Virus.
Version: 7.0.344 / Virus Database: 267.11.9/118 - Release Date: 10/3/2005
2005-10-05 by Bob Paddock
> a 4 layer card.
"A Practical Guide to High-Speed Printed-Circuit-Board Layout
http://www.analog.com/library/analogDialogue/archives/39-09/layout.html
Despite its critical nature in high-speed circuitry, PCB layout is often one
of the last steps in the design process, with sloppy layouts sometimes
causing circuit designs that look good “on paper” to render mediocre
performance. This article addresses high-speed layout from a practical
perspective, discussing topics that can improve circuit performance, reduce
design time, and minimize time-consuming revisions. "
     http://www.softwaresafety.net/ http://www.designer-iii.com/
