LPC2142's ADC problem
2005-10-05 by Eugene Rybkin
Hi ALL!
I tryed to work with ADC on my LPC2142 but I failed :-(
I adjusted ADC to hardware-triggered conversion mode. Conversion
start by rising
edge on the MAT1.0 signal and when is DONE release IRQ. I read ADC's value
in ISR and send
it via UART. IRQ occur normally but extracted values are trash! Also, ADC
fail selftest
when input pin assign to port pin, always read off 0's independently of
port pin
signals. I checked all the power pins (Vdd=Vref=Vdda=3V, Vss=Vssa=0V),
it's connected OK.
Can anybody help me find a mistake?
void T1_setup(void)
FIO0DIR |= BIT(12);
PINSEL0 = (PINSEL0 & ~(BIT(25) | BIT(24))) | BIT(25); // P0.12 as Match
1.0 signal
T1TCR = 2; // stop & reset T0
T1PR = 0;
T1MR0 = PCLK / F_ADC / 2 + 0.5; // F_ADC = 24000 Hz
T1MCR = BIT(1); // Reset on MR1: the TC will be reset if MR1 matches it
T1EMR = (3 << 4) | BIT(0); // toggle External Match bit/output to 1 on
match
T1TCR = 1; // run T0
void ADC_setup(void)
AD0INTEN = 0;
FIO0DIR |= BIT(22) | BIT(29);
FIO0CLR = BIT(29);
// PINSEL1 = (PINSEL1 & ~(BIT(27) | BIT(26))) | BIT(26); // Activate P0.29
as ADC
AD0CR = BIT(21) | ((PCLK / 4000000 - 1) << 8) | BIT(2); // activate AD0.2
VICVectAddr0 = (unsigned int)&AD0_ISR;
VICVectCntl0 = 0x20 | VIC_AD0;
VICIntEnable |= BIT(VIC_AD0);
AD0INTEN = BIT(2);
AD0CR |= (0x6 << 24); // AD0.2 is sampled by rising edge on the MAT1.0
signal
#pragma type_attribute = __arm
void AD0_ISR(void)
FIO0SET = BIT(22);
while ((U0LSR & ULSR_THRE) == 0);
U0THR = (AD0DR2 >> 8) & 0xFF;
FIO0CLR = BIT(22);
Eugene
