Low power multithreaded OS suggestion?
2005-10-06 by guillermoprandi
Hi! I am building a board featuring the LPC2138 µC. This board will basically need to interface with three serial devices (two via internal UARTs and a third via MAX3100, though suggestions are welcomed about this). This device must be very low power; it should wake up only when needed, which is: 1) there's data available from any of the three ports, 2) there's data waiting to be transmitted on any of the ports and the port becomes free and 3) a periodical overall check (every second or so). This means that theoretically the processor can enter the idle state quite often. I'm looking for some (free if possible) multithreaded OS that would handle the transition to the processor's idle state on traditionally blocking calls like fread() and fwrite(), expecting to wake up on interrupt; also, some preemptive multitasking should be supported, in case some thread enters an exceptionally long calculating task. Probably there's no known OS that directly supports this; in this case, I'd like to know which other OS might be a good starting point to accomplish this by making the modifications myself. I'm aiming to use the GNU libraries (I ignore how difficult or messy would it be to modify them to support this). Finally, it is my understanding that the VERY low power "power down" mode would not be useful for my application, since the peripherals (therefore the UARTs and SPI) are shut down in this mode. Any advise or hint on these subjects will be greately appreciated. Guille
