Lpc2000
LPC2148 errata
LPC2148 errata
2005-10-17 by Joel Winarske
Can Phillips apps confirm if the errata for the LPC2148 is identical to the
LPC2138?  This link downloads the errata sheet for the LPC2138:
http://semiconductors.philips.com/acrobat_download/erratasheets/2148.pdf
This document only refers to the LPC2138.  I don't feel comfortable assuming
this is the right errata sheet.
My target application requires six compare positive edge interrupts, and six
timer match interrupts.  Three pairs for each timer.  I plan to implement
workaround as suggested in the errata sheet.
Is there a timetable for a revision that fixes the timer problems?
Joel Winarske
Re: LPC2148 errata
2005-10-17 by dr_danish_ali
Hi Joel,
I found this link only mentions the lpc2148:
http://www.standardics.philips.com/support/techdocs/microcontrollers/pdf/
errata_lpc2148.pdf
off the page:
http://www.standardics.philips.com/support/techdocs/microcontrollers/?scope=LPC2000
But it seems very short for an errata sheet.
Hope this helps,
Danish
Re: LPC2148 errata
2005-10-17 by philips_apps
Joel,
the LPC2148 Errata Sheet is here:
pdf/errata_lpc2148.pdf
It is not identical to the Errata Sheet of the LPC2138 because many
bugs were fixed!
In general please use this link as a start for LPC2000 technical
documents:
http://www.standardics.philips.com/products/lpc2000/all/
Robert
identical to the
pdf
interrupts, and six
implement
> Regards,
> Joel Winarske
Re: [lpc2000] Re: LPC2148 errata
> bugs were fixed!
> documents:
Great I will! Thanks!!
> errata_lpc2148.pdf
> off the page:
> Hope this helps,
> Danish
Yes thanks!!
