Lpc2000
Migrating from 2106 to 2138
2005-10-22 by rtstofer
Other than changing the device header file, am I going to get any big
surprises moving up to a more capable chip?  Yes, less RAM but that
isn't important.  Nor is flash.  I just need the pins.
I am using arm-elf-gcc 3.4.3.
Thanks
Richard
Re: [lpc2000] Migrating from 2106 to 2138
2005-10-22 by Michael Anburaj
http://www.geocities.com/michaelanburaj/downloads/lpc_1.00.zip
includes a ROM monitor image -- the same binary runs
fine on both 210x & 213x --except for memory sizes &
peripherals, there is not much difference (in terms of
basic functionality) between 210x & 213x.
-Mike.
> less RAM but that
> pins.
> Thanks
> Richard
Yahoo! Mail - PC Magazine Editors' Choice 2005
http://mail.yahoo.com
2005-10-22 by Tom Walsh
Device Registers are greatly different in some cases.  The SPI is
capable of sending more bytes per transfer and has a lot more settings.
You'll probably have to make changes to your code to get it to run
against these new settings in the registers.  There is an
IO0{SET,CLR,PIN} and IO1{SET,CLR,PIN} macros...
Your experience with the LPC2106 will benefit you.  BTW, do not trust
any device headers (e.g. LPC21xx.h) that you may download, I had to make
significant changes to the one I found so that it would work with the
LPC2138.  There were missing definitions, a lot of them!
TomW
>Thanks
>Richard
>Yahoo! Groups Links
