Lpc2000
Bootloader <-> UserProgram
2005-10-31 by ucsebbel
I have a little problem.
I build my own evaluation board based on the LPC2214. I can start the
bootloader, upload data and download data (also verify).
But the board never start the normal user-program that I've uploaded
in the FLASH.
After a normal reset the Bootloader and the user-program  don't start.
So my question, what can the LPC do after a reset??
I don't have a debug interface or anything else. I own only a serial
cable.
Hopefully somebody can help me.
Perhabs I forget a pin which stuck at low or high and so the LPC start
into another mode ???
Sebastian
Re: [lpc2000] Bootloader <-> UserProgram
2005-10-31 by Tom Walsh
ucsebbel wrote:
>Hi,
>in the FLASH.
>cable.
P0.14 must be pulled to +3.3 volts, the Checksum must exits in the
interrupt table.  Otherwise, the chip will simply enter into the monitor
rom and not run your program.
If you are going to do development on the LPC2xxx chips, I highly
recommend that you get a JTAG of some kind working for you.  Their are
cheap-o parallel port wigglers which you can build for a few dollars up
to spending several thousand dollars for a high-end Abatron BDI2000 (I
got me one of these ;-))
Your program could have run, then did an illegal memory acess (DATA
ABORT) or the stack register was not set properly and you returned into
an invalid opcode (UNDEF ABORT)...  JTAG debugger will let you see what
happened, until then, it is anyones guess what went / is wrong.  Stop
guessing and start working, get a debugger together!
TomW
>Regards
>Sebastian
>Yahoo! Groups Links
