Lpc2000
LPC2148 and SD and Write Protect
2005-10-31 by seangra
Does anyone know (or have any references) for code for connecting an
SD card to the LPC2148?  I've seen the olimex specs and I know that
it's a basic SPI interface, but I'm just wondering about any other
actual documentation or code that uses this.
Additionally how does the write protect circuit function?  I haven't
been able to find any documentation or specification that tells me how
the write protect circuit functions.  From what I understand it's a
simple basic switch, pins 10 and 14 get connected together when the
switch is closed.  But if this is the case, why did olimex hardwire
Vcc and Vss (via resistors) on this, why not just leave the pins
unconnected?  If I wanted to use the WP capability, do I just connect
one to pull-up'd Vcc, and the other to a GPIO on the LPC?
Thanks for any help.
Re: [lpc2000] LPC2148 and SD and Write Protect
2005-10-31 by Tom Walsh
Start here: http://www.elinux.org/wiki/MMC
Re: LPC2148 and SD and Write Protect
2005-10-31 by rtstofer
From the gumstix group (www.gumstix.com or .org) I think I heard
that the SD interface is proprietary and available to PAYING members
only.  The MMC interface is available.
This could be way off but I think it is correct.
Richard
--- In lpc2000@yahoogroups.com, Tom Walsh <tom@o...> wrote:
an
that
other
haven't
me how
a
hardwire
connect
2005-10-31 by Joel Winarske
Sean wrote:
>Does anyone know (or have any references) for code for connecting an SD
>card
>to the LPC2148?  I've seen the olimex specs and I know that it's a basic
>SPI
>interface, but I'm just wondering about any other actual documentation or
This is a pretty important document to have:
http://sandisk.com/pdf/oem/ProdManualSDCardv1.9.pdf
>From what I understand it's a simple basic switch, pins 10 and 14 get
>connected together when the switch is closed.  But if this is the case, why
>did olimex hardwire Vcc and Vss (via resistors) on this, why not just leave
>the pins unconnected?  If I wanted to use the WP capability, do I just
>connect one to pull-up'd Vcc, and the other to a GPIO on the LPC?
Yes the Write-Protect and Card Present are just simple switches implemented
in the socket.  What current is running through the switches on the Olimex
design? Depending on the current it may be there to help maintain oxidation.
Just a thought.
Joel
2005-10-31 by mark_dell555
I was looking into SD a few days ago, and wikipedia has a nice
section, including 2 links to specs in pdf.
check out:
http://en.wikipedia.org/wiki/SD_card
and the 2 links:
http://www.sandisk.com/pdf/oem/SD_SDIO_specsv1.pdf
http://www.sandisk.com/pdf/oem/SD_Physical_specsv101.pdf
I think that should be a good start.
Mark
2005-11-01 by seangra
Thanks, that's exactly what I needed:
A proper, matched, switch on the socket side will indicate to the
host that the card is write-protected or not. It is the
responsibility of the host to protect the card. The position of the
write protect switch is un-known to the internal
circuitry of the card.
oxidation.
They have Vcc -> 33kohm -> WP1 ... WP2 -> 2kohm -> GND
So since the internal circutry has no idea about this, if I don't
care about the write protect, then I can just leave WP1 and WP2 not
connected, so why would they do that?  Unless they were planning at
some point in time to also connect WP1 to a GPIO on the micro?
Re: [lpc2000] Re: LPC2148 and SD and Write Protect
2005-11-01 by Joel Winarske
> oxidation.
They tie WP and CP to inputs on this design:
http://www.olimex.com/dev/images/sam7-p64-sch.gif
I imagine the resistors are populated as a feature, so if you want either or
both signals simply add a jumper to the desired input pins.  If you are
using a socket with higher quality metal, and depending on the end product
environment, contact oxidation may never be a concern.  The finger contacts
that connect to the actual SD card are self cleaning.
Joel
