Lpc2000
Philips Utility Problem (Part 2)
2005-11-01 by Leighton Rowe
Hey guys,
I recently mentioned a problem where the Philips Flash utility
partially works with my lpc2114 board and gives communication errors
whenever attempting to Erase Flash or Download code to the board.
I troubleshooted the RS232 interface, and all rs232 signals are
working OK now, but I still get comm errors with the Phillps
Utility. I think that I'm possibly dealing with a more serious
problem here, as I can't even download code into flash memory of the
same board thru the JTAG interface.
I sometimes use the Debug Utility in the IAR Software as an
alternative to flash program and debug applications on the lpc2114
chip. This surely works. However, the above method didn't even work
with the same board. The IAR flash programming tool executed
normally while downloading code unto the board. However afterwards,
the memory dump showed no sign that the flash memory got programmed.
The application's memory area showed nothing but 1's or 0xFF's,
while the reset vectors supposedly points to the bootloader and not
the application.
Let me know what you think. I think that I'm possibly dealing with a
corrupted chip.
Leighton
Re: [lpc2000] Philips Utility Problem (Part 2)
2005-11-01 by Peter Jakacki
Leighton,
I had problems downloading when I used to use a particular USB-RS232
adapter which funnily enough was based on an older Philip's chipset.
There does not appear to be any problem if I use an internal coms port
or a Silabs based USB adapter. This may be related to some timeout or
handshake issue. Even at lower baud-rates I would have coms failures.
The laptop I used at the time was running on a power-pack and I would
also notice mains leakage on the order of 100's of microamps (it
bites!). This may not be a problem but I use my own isolated USB coms now.
Could your problem be anything along these lines?
*Peter*
Leighton Rowe wrote:
> Hey guys,
> the application.
> corrupted chip.
Re: Philips Utility Problem (Part 2)
2005-11-02 by Leighton Rowe
RS232
chipset.
port
or
failures.
would
coms now.
> *Peter*
Well, the philips utility's communicating with the lpc thru the
internal com port. I get the same problem at different baud rates,
but I'm not sure whether or not the problem's a handshaking issue.
The philips synchronizes OK, so probably the RTS line's functioning
correctly. So the handshaking's probably working right.
The only set of clues I could look at now is the serial data log
between the PC and the lpc. I haven't yet figured out the returned
code (bytes) from the lpc yet. However, looking at the communication
log during an 'erase command' sequence, I see the philips utility
synchronize with the '?' OK and then continues to communicate bytes
until the lpc stops responding. Nothing happens for a while and then
the communications error shows up (definitely a timeout issue). There
isn't any immediate sign of framing errors occuring.
I don't know much about the philips bootloader protocol, but I think
there's a good chance that the chip's not sending the right response
bytes, leading to a comm timeout. I'll probably have to reproduce &
post the communication log later.
Leighton
