Milter-greylist
Index last updated: 2026-04-28 23:32 UTC
tune behavior according to SPF test
2015-08-26 by patpro@...
I would like to trigger a different behavior for different users. Basically, I need:
- rcpt @... to be greylisted -> always, for a given delay
- other rcpt to be greylisted -> only if SPF test fails, for a different delay
I've tried:
racl greylist rcpt /@...$/ delay 5h autowhite 2d
racl greylist default delay 2m autowhite 5d
but of course a successful SPF test yields to whitelist "rcpt /@...$/". So I've tried:
racl greylist rcpt /@...-lyon2.fr$/ delay 5h autowhite 2d
racl whitelist spf pass
but again, "racl whitelist spf pass" triggers even if rcpt matches /@...-lyon2.fr$/.
Any idea?
regards,
pat
Re: [milter-greylist] tune behavior according to SPF test
2015-08-26 by Jim Klimov
26 \u0430\u0432\u0433\u0443\u0441\u0442\u0430 2015�\u0433. 13:44:14 CEST, "patpro@... [milter-greylist]" <milter-greylist@yahoogroups.com> \u043f\u0438\u0448\u0435\u0442:
>Hi,
>Basically, I need:
>different delay
>I've tried:
>/@...-lyon2.fr$/.
>Any idea?
>regards,
>pat
 You can use variable assignments to store results of tests (such as spf hit) and then build some result actions (gwb-lists with various timeouts and messages) based on collected score(s). It is not that well documented, so look up list archives for Manu's advice to myself about 1-2 years ago.
Jim
Typos courtesy of K-9 Mail on my Samsung Android
2015-08-26 by Patrick Proniewski
On 26 août 2015, at 20:58, Jim Klimov jimklimov@... [milter-greylist] wrote:
> 26 августа 2015 г. 13:44:14 CEST, "patpro@... [milter-greylist]" <milter-greylist@yahoogroups.com> пишет:
>> Hi,
>> Basically, I need:
>> different delay
>> I've tried:
>> Any idea?
>> regards,
>> pat
Thanks for the tip, I'll try ASAP. But in the mean time, I'm very surprised… the man greylist.conf clearly states:
       Entries in the access-list are evaluated sequentially, so order is very
       important. The first matching entry is used to decide if a message will
       be whitelisted or greylisted. A special default clause can be  used  in
       the  last  ACL  entry as a wildcard.
End provides examples. So according to this documentation, this should yield to the proper result:
(I've tried /.*@sub\.domain\.tld$/ also)
If rcpt match the RE, evaluation should stop at first line.
If rcpt does not match, it should either match spf pass or default.
In real life, this does not work.
regards,
Pat
RE: [milter-greylist] tune behavior according to SPF test
2015-08-26 by Bruncsak, Attila
> From: milter-greylist@yahoogroups.com [mailto:milter-greylist@yahoogroups.com]
> Sent: mercredi, 26. août 2015 21:40
> To: [milter-greylist]
> Subject: Re: [milter-greylist] tune behavior according to SPF test
> On 26 août 2015, at 20:58, Jim Klimov jimklimov@cos.ru [milter-greylist] wrote:
> > 26 августа 2015 г. 13:44:14 CEST, "patpro@patpro.net [milter-greylist]" <milter-greylist@yahoogroups.com> пишет:
> >> Hi,
> >> Basically, I need:
> >> - rcpt @sub.domain.tld to be greylisted -> always, for a given delay
> >> different delay
> >> I've tried:
> >> racl greylist rcpt /@sub.domain.tld$/ delay 5h autowhite 2d
> >> /@sub.domain.tld$/". So I've tried:
> >> /@sub.domain.tld$/.
> >> Any idea?
> >> regards,
> >> pat
> regards,
> Pat
Instead of /@sub.domain.tld$/ try with /@sub\.domain\.tld>$/ .
On 26 août 2015, at 21:50, 'Bruncsak, Attila' attila.bruncsak@... [milter-greylist] wrote:
>> regards,
>> Pat
> Instead of /@...$/ try with /@sub\.domain\.tld>$/ .
Lovely, works perfectly! Thanks a lot. You saved the day.
regards
Pat
