Milter-greylist
Index last updated: 2026-04-28 23:32 UTC
can't read SMFIC_MAIL reply packet header: Broken pipe
2017-08-09 by Mauricio Teixeira
Guys,
I've been getting this error at random times in my logs:
postfix/smtpd[18769]: warning: milter unix:/run/milter-greylist/milter-greylist.sock: can't read SMFIC_MAIL reply packet header: Broken pipe
Because of that, postfix drops the connection on the floor, and the sender gets a "Service unavailable error".
I don't see any other error messages around the same time that would give me any indication about what is going on. I am leaning around a possible racing condition with the milter-greylist software itself, maybe it's unable to cope with the amount of connections and the size of the database, but I am not sure, and I don't know how to debug the issue without enabling debug mode (which would fill out my logs with way more information than I can process).
This is affecting less than 1% of the incoming connections, but some times it happens with important senders, which make my customers pretty upset.
Anybody got any ideas?
Mauricio Teixeira
Raleigh/NC/USA
mauricio.teixeira{at}gmail.com
(irc: netmask on freenode)
Re: [milter-greylist] can't read SMFIC_MAIL reply packet header: Broken pipe
2017-08-13 by manu@...
Mauricio Teixeira mauricio.teixeira@... [milter-greylist]
No log on milter-greylist side?
Do you use a network-based clause in your ACL, such as a DNSRBL? This
may be a timeout.
Emmanuel Dreyfus
http://hcpnet.free.fr/pubz
manu@...
2017-08-14 by Mauricio Teixeira
No extra logs on milter-greylist side.
We do heavily use DNSRBL, I think 5 or 6 checks. I was already suspicious this could be the issue, but how can I debug which one of the DNSRBL checks would be timing out?
On Sun, Aug 13, 2017 at 7:41 PM, manu@... [milter-greylist] <milter-greylist@yahoogroups.com> wrote:
Mauricio Teixeira mauricio.teixeira@gmail.com [milter-greylist]
may be a timeout.
Emmanuel Dreyfus
manu@...
Mauricio Teixeira
Raleigh/NC/USA
2017-08-14 by John_Damm_S=c3=b8rensen
Do you run a local caching name server?
If not I guess that might help you getting rid of the time outs.
/john
Den 14-08-2017 kl. 16:54 skrev Mauricio Teixeira
mauricio.teixeira@... [milter-greylist]:
> <mailto:manu@...> [milter-greylist]
>     <mailto:mauricio.teixeira@...> [milter-greylist]
>     SMFIC_MAIL reply
>     may be a timeout.
>     Emmanuel Dreyfus
>     manu@... <mailto:manu@...>
> Mauricio Teixeira
> Raleigh/NC/USA
> mauricio.teixeira{at}gmail.com <http://gmail.com>
I was considering that. Will try it. Thanks.
On Mon, Aug 14, 2017 at 12:55 PM, John Damm Sørensen john@... [milter-greylist] <milter-greylist@yahoogroups.com> wrote:
/john
Den 14-08-2017 kl. 16:54 skrev Mauricio Teixeira mauricio.teixeira@... [milter-greylist]:
may be a timeout.
Emmanuel Dreyfus
manu@...
Mauricio Teixeira
Raleigh/NC/USA
Mauricio Teixeira
Raleigh/NC/USA
2017-08-14 by manu@...
Using tcpdump?
Emmanuel Dreyfus
manu@...
milter-greylist passing useless queueid to spamd
2017-12-18 by John_Damm_S=c3=b8rensen
My maillog contains this type of of error for each processed mail when
spamd runs as user root:
Dec 18 12:10:24 www spamd[5198]: spamd: handle_user (getpwnam) unable to
find user: 'vBIBAIFU006181'
and this when spamd runs as user sa-milt:
Dec 18 17:14:25 www spamd[11859]: spamd: handle_user (userdir) unable to
find user: 'vBIGEJAn012103'
Spamd is trying to change user ID to the ID of the user passed to spamd
with this code in spamd.c:
 �snprintf(buffer, SPAMD_BUFLEN,
 ��������� "CHECK SPAMC/1.2\r\n"
 ��������� "Content-length: %d\r\n"
 ��������� "User: %s\r\n\r\n",
 ��������� (unsigned int)(priv->priv_msgcount + strlen(rcvhdr)),
 ���������� priv->priv_queueid);
priv->priv_queueid is picked up from the sendmail macro $i containing
the queueid of the current mail i:
 From milter-greylist.c:
if ((priv->priv_queueid = smfi_getsymval(ctx, "{i}")) == NULL) {
It seems to me that the queueid is useless to spamd and I suggest it to
be replaced/removed.
John
Denne e-mail blev kontrolleret for virusser af Avast antivirussoftware.
https://www.avast.com/antivirus
