MOTM
suggested mod for motm700 (longish)
2001-02-09 by norman fay
This is a module I haven't got yet, though I do mean to get one, as I
can imagine several uses for it.  At the same time, I've been looking at
the serge "com" (dual comparator) and comparing them feature-wise.
Though both modules are based around a voltage-controlled switching
function, both modules produce different results.  The MOTM switcher,
I'm sure you all know about.  The serge comparator, OTOH, has two inputs
marked + and -, a threshold knob and a single output per channel.  what
they do is this:  one runs a different voltage/signal into each channel.
If the + signal is greater than the - signal, the output goes high (+5v)
if not, it goes low (0v)  Using the threshold control, one can either
generate square waves/pulses from a single input, or raise or lower the
+ signal (I think....).  I've been racking my brains trying to come up
with a way for the motm700 to do this.  The voltage bit is easy - set
the mode to voltage, and feed it with +5v into one input and 0v into the
other (you could use   l. hendry's octave switcher to generate the 5v)
however, the dual cv inputs are a problem....the only way to do it would
be to add another cv input to each half of the module, which would
interact with the "switch" knob.  In this case then, if the
signal/voltage at "cv in" is greater than that at our new input, the
module would switch one way, if it were lower, it would switch the other
way. In this case, the "switch" knob could add or subtract from the
voltage present at the new input, thus acting as a threshold control.
Now, I'm absolutely *sure* that there are folks on this list who could
perform this mod!
Now, the question you'll be asking is this:  why?  Well, here's a few
possibilities:
1/ from the MOTM700 page at www.synthtech.com:
"audio demo - chopped up audio switching between 2 waveforms with the cv
as a 250 hz triangle.  you can hear the timbre shift as we manually move
the SWITCH control"
with this extra cv in, you could control this timbre shift with an
envelope or an lfo.
2/ with a sequencer - clock the sequencer with a narrow pulse wave lfo
signal, also run pulse wave into MOTM lag processor (fastest attack,
slower decay) run lag proc out into CV in of MOTM700, run cv source (eg
lfo or second row of sequencer knobs) into new switch CV input. 5v into
one i/o socket, 0v into other - result = VC gate time!
3/ vco triangle wave into cv input, lfo or adsr into new input, +5v into
one i/o socket, 0v or -5v into other - result = second (or third, using
both sections of motm700) pwm wave from single VCO!
pretty cool, eh?  Any thoughts?  Anyone fancy getting to work on this?
please!
best wishes
norman fay
Re: suggested mod for motm700 (longish)
2001-02-09 by mate_stubb@yahoo.com
This mod has been brought up once or twice before here. I vaguely
remember looking into it briefly, and that it was not entirely
straightforward. You'd have to replace the simple pot / voltage
divider on the comparator hysteresis (positive feedback) loop with
some sort of opamp summing node. So at a minimum, find panel space
for 2 more jacks, and add an extra pcb with a couple of dual opamps
and some resistors. So circuit wise it's not bad, but physically it's
a little work.
BTW, the Serge is just a digital comparator (ignoring the staircase
part). The 700 is a bi-directional audio router that can be patched
with dc voltages to give you a digital comparator, and so is
considerably more flexible in that sense.
Moe
I
looking at
switcher,
inputs
what
channel.
(+5v)
either
up
set
into the
5v)
would
other
control.
could
> perform this mod!
few
> possibilities:
the cv
move
> the SWITCH control"
> envelope or an lfo.
lfo
(eg
into
into
using
this?
> please!
> best wishes
> norman fay
Re: [motm] suggested mod for motm700 (longish)
2001-02-09 by Thomas Hudson
You can get them same effect by adding a control voltage to the waveform
you're using at the CV input of the 700. Imagine you have your switch
set to
occur at the zero crossing of your waveform. As you add a positive voltage
you bias the waveform so that switching occurs more on the negative peaks,
as you subtract voltage, the waveform moves down and switching occurs on
the positive peaks. Sort of "If you can't raise the bridge, lower the river."
Larry first suggested this to me when I was wanting the same mod.
Tomy
> perform this mod!
> possibilities:
> the SWITCH control"
> envelope or an lfo.
> please!
> best wishes
> norman fay
2001-02-09 by J. Larry Hendry
Norman,
This is some really great stuff.  You got me thinking WHY?  And then you
answered.  A very thoughtful mail no doubt.
The CV input of the 700 already feeds a comparator.  The + side fed by the
switch pot is already scaled for + / - 5 volts by the resistors at the ends
of the pot.  So, I cannot see any reason that you could not use a voltage
input here instead of the switch pot.  My lack of expertise leaves me with
some questions though.
Standard Stooge Disclaimer - I have not tried this.  Do not do this.  This
is for the purpose of discussion.
1 - would you need to buffer the input - I don't see why
2 - would you need a filter on the CV input like Paul has
     put on the actual CV input (R9 and C7).
But, in general, it seems like you should be able to interrupt the
connection between VR1 and the LM311 pin 2.  Put your CV input jack here and
set VR1 wiper to the switch on the new jack to that when nothing is plugged
into the new CV jack, VR1 functions as normal.
If you wanted to still have the biasing ability of VR1, it would seem to me
you would need to add a summing stage to add the voltages of the pot and
this new CV input prior to going to the comparator.  But, that seems
unnecessary and beyond what you were trying to accomplish.
Very interesting.  I like your thoughts on this.
Larry
P.S.  without modification, the 822 voltage switch will only output 3.917
volts max.
To: <motm@yahoogroups.com>
Sent: Friday, February 09, 2001 6:58 AM
Subject: [motm] suggested mod for motm700 (longish)
perform this mod!
possibilities:
the SWITCH control"
envelope or an lfo.
please!
best wishes
norman fay
2001-02-10 by J G Wong
I just ordered this module , now what the hell are I going to do .  Any
of you
readers for any amount of time knows that Norm Fay is not f to be
regarded in the least bit  lightly..  those of us who make serious noise
or serious money doing this must pause.   ..  C'mon guys I work for the
feds and have been detached hence no time.to volunteer.
Help
G Wong
"J. Larry Hendry" wrote:
> Norman,
> Larry
> volts max.
> From: norman fay <NFAY@...>
> perform this mod!
> possibilities:
> the SWITCH control"
> envelope or an lfo.
> please!
> best wishes
> norman fay
Re: [motm] Re: suggested mod for motm700 (longish)
2001-02-10 by norman fay
In message <9618pa+d651@...>, mate_stubb@... writes
>a little work.
I'm not up to the circuit bit, but the board (if its only a couple of
dual opamps & some resistors, this should be stripboardable, yes?) and
the 2 extra sockets shouldn't be an issue for me - BTW, I figure a good
place for the sockets would be if you were to draw an imaginary line up
from the third column of sockets on the existing module, and intersect
it with a line drawn from the two rows of LEDs.
Aye...I'm a greedy sort, though.  <wails> I WANT IT ALL!! </wails>
I think I will move the MOTM700 up my schedule of modules to buy,
though.
best etc
norman fay
2001-02-10 by mate_stubb@yahoo.com
> BTW, I figure a good place for the sockets would be if you were to
> draw an imaginary line up from the third column of sockets on the
> existing module, and intersect it with a line drawn from the two
> rows of LEDs.
Glancing at mine, I don't think you'll totally clear the pcb at that
location - there are tall electrolytic caps that infringe into at
least one of those locations.
Moe
2001-02-10 by J. Larry Hendry
Actually, I think the spaces as I understand what Norman describes look
pretty clear in the back.  I would have chosen the spots directly under the
pots (in line), but those just won't work at all.  But, if they were put
just outside the box to the right of the LEDs, I think they would clear OK.
They you could add a white line down and over from the bottom of the pot
scale.
Just my $.02
Larry
Sent: Saturday, February 10, 2001 12:35 PM
Subject: [motm] Re: suggested mod for motm700 (longish)
> rows of LEDs.
Moe
