Ground Loops
2001-02-11 by GeorgeK
Well, I just finished building my first modules, the 900, 120, 420 and 320, and amazingly everything seems to work (and looks great too!) What a sweet filter the 420 is! (In just a few more days, my girl gets some flowers, and I get some sound sources - my 2nd order's in!) I've run into a little problem, however. When the 900 power supply is installed into a rack with the modules and is powered on, I begin to pick up some minor 60hz hum; not much, but enough to ruin the dark background - Bummer. (FYI, the rack is wood frame with metal rails. A mixer is in a separate all-metal rack. Everything is plugged into the same power strip. Patch cords are shielded) I pick up hum regardless of which jack/module I plug into. I visually checked all coax solder joints and ground wires; everything looks ok. Funny thing is that even when I disconnect all of the modules' power cables from the 900, I still pick up hum whenever the 900 is on. There's no hum when the 900 is not in the rack, whether connected to and powering the modules or not. Is appears the AC ground is part of the common ground with the modules when installed in a rack with metal rails. This is by design, correct? Is it possible that the mixer being in a separate rack is a problem? If anyone on the list has some insight, that would be great. Cheers, George
