MOTM
Mixer design as of now
2001-03-04 by Paul Schreiber
Here is what I'm about to commit to for the mixer unless someone else
convinces me elsewise:
* 2U wide
* dual 3:1 or single 6:1
* it splits into dual mode when a jack is inserted into OUT 1
* DC path. Can mix AC and/or DC. Uses OP285GP amps. This is a lower
offset/drift version of the OP275GP
* Has a  -5V to +5V DC bias pot, which is switch in/out via panel switch.
Only offsets OUT 2.
* 2 reversing attenuators (1 in each mixer)
* NO 'master Gain' it takes a dual pot and I'm not going down that road
(like 18 weeks lead time).
* $169 kit/$229 assembled
*easy to build, no trimmers. About as hard as a '420 kit.
Well?
Also: I have some new Switchcraft 113 jacks for sale. The are like the 112As
except:
* single open circuit (doesn't have the 3rd shorting lug)
* has an isoloated N.O (Normally Open) switch (on 2 seperate lugs)
The mixer needs a 113E version, which has a N.C. switch (grrrrrr.....)
Regular about $2.50ea. I'll sell em for 10 for $8.00 That's cheap! You don't
*have* to use the switch :)
Paul S.
Re: Mixer design as of now
2001-03-04 by mate_stubb@yahoo.com
Yeah, sure Larry! We just caught you trying to corner the market<LOL>!
What's that now, at least 20 times the Stooge has managed to send
private mail to the list?
Moe
--- In motm@y..., "J. Larry Hendry" <jlarryh@i...> wrote:
> (**(^&%$$%*&)_*(R^&  supposed to be private ... I HATE this F***ing
rely
> function.
> From: J. Larry Hendry <jlarryh@i...>
> To: <motm@y...>
> Sent: Sunday, March 04, 2001 12:35 AM
> Subject: Re: [motm] Mixer design as of now
> Sound great Paul.  I do have one question.  You said switches when
the jack
> is inserted into OUT 1.  Intuitively, I would consider Out 1 the
one to be
> active when in 6 X 1 mode.  If the switch in one output 1, then out
2 must
> be the one active for 6 x 1 mode.  Seems backwards.  However, I do
think the
> DC bias needs to be active in the 6 x 1 mode.
> In reference to the special jacks, I guess you just purchased the
wrong ones
> and need to move them.  Right?  You need normally closed, these are
normally
> open (so the isolated switch shorts when the jack is inserted?)  If
so, I
> would be willing to take a large quantity off your hands at that
price.  How
> many do you have?
> Larry
> From: Paul Schreiber <synth1@a...>
> To: MOTM listserv <motm@y...>
> Sent: Saturday, March 03, 2001 11:32 PM
> Subject: [motm] Mixer design as of now
else
> * 2U wide
switch.
> Only offsets OUT 2.
road
> Well?
the 112As
> except:
(grrrrrr.....)
You don't
> Paul S.
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This sounds good to me. So 7 knobs, 1 switch, 8 jacks, right? A
typical full 2U panel.
Do you need a mockup? What do you want the labels to say?
Your thinking behind making OUT2 the 6x1 output is that with only 1
output jack inserted, the main out is at the corner of the module?
Either OUT1 or OUT2 as the 6x1 output works for me. I agree with
Larry that whichever output works as the 6x1, that's the one that the
offset pot must be summed with, so that it can work at all times.
Moe
else
> * 2U wide
switch.
> Only offsets OUT 2.
road
> Well?
the 112As
> except:
(grrrrrr.....)
You don't
> Paul S.
2001-03-04 by J. Larry Hendry
Sound great Paul.  I do have one question.  You said switches when the jack
is inserted into OUT 1.  Intuitively, I would consider Out 1 the one to be
active when in 6 X 1 mode.  If the switch in one output 1, then out 2 must
be the one active for 6 x 1 mode.  Seems backwards.  However, I do think the
In reference to the special jacks, I guess you just purchased the wrong ones
and need to move them.  Right?  You need normally closed, these are normally
open (so the isolated switch shorts when the jack is inserted?)  If so, I
would be willing to take a large quantity off your hands at that price.  How
many do you have?
Larry
To: MOTM listserv <motm@yahoogroups.com>
* 2U wide
Only offsets OUT 2.
Well?
except:
Paul S.
(**(^&%$$%*&)_*(R^&  supposed to be private ... I HATE this F***ing rely
function.
To: <motm@yahoogroups.com>
many do you have?
Larry
* 2U wide
Only offsets OUT 2.
Well?
except:
Paul S.
2001-03-04 by bruce@sigalarm.com
The kick is up...
And its good!!!
That and a triple VCA and I can rule the world.  My Matrix 12 has
enough VCA's to attenuate a solar eclipse... So I guess I got spoiled,
now I want all my control sources to be able to be VCA's with an
envelope, or / and a lag processor.. (you get the idea).
Bruce
RE: [motm] Mixer design as of now
2001-03-04 by Tentochi
What is the model number?
Can you desing the PCB (and FP) so we can add this ourselves at a later
time????  That would be cool.
> cheap! You don't *have* to use the switch :)
Did you order the wrong ones?  How many do you have?
Cheers!
Shemp
Re: [motm] Re: Mixer design as of now
> From: <mate_stubb@...>
> the market<LOL>!
Well, not corner the market.  But, I do have these magic busses that require
48 jacks each.  I know there will be 4 of them.
> to send private mail to the list?
Careful Moe.  I have some other photos of you too.  Maybe I
should call your wife... nyck nyck...
Just kiddin'
Larry
2001-03-04 by elhardt@aol.com
synth1@... writes:
>>* 2 reversing attenuators (1 in each mixer)<<
Am I to understand that this will allow us to subtract a signal from the mix?
-Elhardt
2001-03-04 by Dave Hylander
How about + and - output jacks for the mixed output?
2001-03-04 by Microtonal
Instead of using Out1 or Out2 to switch from single to dual mode, I would
recommend a real switch.  This could let you use both Outs in Dual mode and
help prevent confusion about which jack switches the unit to dual mode.  It
also would allow switching in/out additional sources on the fly to your
existing audio or modulation sources, a very useful realtime function.
John Loffink
microtonal@...
Sent: Sunday, March 04, 2001 12:34 AM
Subject: [motm] Re: Mixer design as of now
> Moe
> else
> > * 2U wide
> switch.
> > Only offsets OUT 2.
> road
> > Well?
> the 112As
> > except:
> (grrrrrr.....)
> You don't
> > Paul S.
No room.
Paul S.
Sent: Sunday, March 04, 2001 5:05 AM
Well, add it with positive or negative polarity. In the case of a dc
signal, you are adding negative offset. Is that what you meant?
Moe
--- In motm@y..., elhardt@a... wrote:
> synth1@a... writes:
from the mix?
> -Elhardt
Where would you put the extra jack? There are already 8!
Moe
else
2001-03-04 by jwbarlow@aol.com
In a message dated 3/4/2001 1:58:04 AM, elhardt@... writes:
>synth1@... writes:
>mix?
That would be my understanding!
BTW, you may remember a long while ago I was raving about using inverters to
add and subtract different waveforms from a single VCO (allowing one to
reinforce the fundamental for example)-- I thought this technique needed a
closer look (listen). The addition of these reversing attenuators is a real
plus IMO, and they will of course, be useful in all the normal CV mixing
functions too.
JB
Is there a picture of it somewhere?  I didn't know there were 8.
dave
I've whipped up a couple of panel candidates, neither of which has
been blessed by Paul. One of them incorporates John L.'s suggestion
for a dedicated MODE switch.
http://motm.retrosynth.com/moe_stuff/future_motm/m-mixer.jpg
http://motm.retrosynth.com/moe_stuff/future_motm/m-mixer2.jpg
Enjoy, drool, etc.
Moe
Dave's Hot Rod MOTM Shop
http://www.users.qwest.net/~daveb2
> dave
This is what I'd like to see.  The switch changes between 2x3 and 1X6, and
there is a LED :).  Sorry about the resolution.  It's difficult to export
out of Acad2000.
Dave
In a message dated 3/4/2001 10:32:51 AM, mate_stubb@... writes:
I think I prefer this one for the reasons John gave previously.
Beyond that, I like everything that Paul has incorporated into this module so
far.
Hey, it's rated XXX, for extreme mixing no doubt!
JB
Sorry for the attachment, that was supposed to go private to Dave B.
dave (acting like a stooge)
>out of Acad2000.
>Dave
I like the dedicated mode switch on mixer2.
dave
Har! Round Three of the Mixer Wars erupts again! I posted both panel
designs to start a discussion, in part because some of the newer list
members are complaining about all the off topic posts, and we haven't
had a design brawl in awhile. So if you're a list old-timer and are
tired of all this, blame me.
Be aware - adding a second switch ups the module cost $5 - $10. Still
want it?
Moe
> I have to disagree with the prevailing opinion here.  The jack
switching is
> more efficient in that you do not need an external switch and you
leave the
> panel space open for other things.  What is it that the external
switch gets
> you?  Nothing I can see.
> with only one output connected, it is a 6 to 1 mixer.  With both
jacked, it
> is a 3 to 1 mixer times 2.  What could be any more simple than
that.  I have
> a DIY mixer built like that except  it is either 4 to 1 or 2 to 1
times 2
> with dedicated bias and LEDs on each 1/2.  when you plug in the
second
> output, it splits the mixer, that simple.  I also added 2 LEDs that
indicate
> whether the mixer is in 4 to 1 or 2 to 1 x 2 mode.  However, I have
found
> that the LEDs are just not needed.
> So, I think Paul's concept of a switching jack is still best, but I
think
> the "switch jack" should be the second output not the first.
Think about
> it -- one output plug and it is 6 to 1 --  two output plugs and it
> automatically splits off  3 of the inputs to the second output.
Highly
> intuitive.
> Larry H
> From: Dave Hylander <david@h...>
> To: <motm@y...>
> Sent: Sunday, March 04, 2001 1:06 PM
> Subject: Re: [motm] Re: Mixer design as of now
> dave
2001-03-04 by Tony Allgood
>So, I think Paul's concept of a switching jack is still best...
Absolutely, no need for the switch.
>... but I think the "switch jack" should be the second output not the
first.
But I don't get this. Surely the top output should be the sum of the top
row of inputs. Inserting a jack in these automatically disconnects this
from the next three. Its also easier to do, since you can do this with
the NC contacts in the 112A.
Its what I would do :-)
Tony Allgood  Penrith, Cumbria, England
Oakley Modular Synth and TB3030:
www.techrepairs.freeserve.co.uk/projects.htm
My music: www.mp3.com/taklamakan
2001-03-04 by mark@indole.net
At 2:29 PM -0600 03/04/01, J. Larry Hendry wrote:
>I have to disagree with the prevailing opinion here.  The jack switching is
>more efficient in that you do not need an external switch and you leave the
>panel space open for other things.  What is it that the external switch
>>gets you?  Nothing I can see.
I agree.  A variety of switched jacks is one reason to choose 1/4".  You
might as well take advantage of it.
The only advantage to additional switch would be if the first output was
the first three inputs, and the second output was the second three outputs
or all six outputs depending solely on the switch regardless of whether or
not you are using the first output.  That way you could get a three channel
submix and a six channel main mix from the same six inputs.
You can also use a 1/4" jack on the outputs so its the negative when
inserted half way.  In fact, this would be a nice standard for every output
in the system!!
>with only one output connected, it is a 6 to 1 mixer.  With both jacked, it
>is a 3 to 1 mixer times 2.  What could be any more simple than that.
Two separate modules??
>So, I think Paul's concept of a switching jack is still best, but I think
>the "switch jack" should be the second output not the first.   Think about
>automatically splits off  3 of the inputs to the second output.  Highly
>intuitive.
Hmmm...my intuition tells me the output for all six should be all the way
to the bottom, and all the way to the right.  The sub-out for the first
three should be to the left of the output of the second three.
>out of Acad2000.
You want a switch and an LED??  What does the LED tell you??  Which way the
switch is?!?
panel space open for other things.  What is it that the external switch gets
is a 3 to 1 mixer times 2.  What could be any more simple than that.  I have
a DIY mixer built like that except  it is either 4 to 1 or 2 to 1 times 2
with dedicated bias and LEDs on each 1/2.  when you plug in the second
output, it splits the mixer, that simple.  I also added 2 LEDs that indicate
whether the mixer is in 4 to 1 or 2 to 1 x 2 mode.  However, I have found
intuitive.
Larry H
dave
2001-03-04 by bigd@buffalo.com
well unfortunetly for some who use are MOTM in the studio, having to explain to
a producer or guitarist patching things this everytime is a pain. Id prefer the
switch as well. Also Dave Hylanders note about a LED would be cool.
Jim
> intuitive.
> Larry H
> From: Dave Hylander <david@...>
> dave
> first.
For everyone who says there's no need for a mode switch, look at all the
arguments about whether the first or second output would activate the
switching.  This would not be confusing though...
Nuff said.
John Loffink
microtonal@...
Well, after looking at Moe image 1 as Paul has indicated, I agree.  And
I agree that the switching can be done with the NC contact of a 112A.
although that might not fit Paul's way of doing things.
You can also do it with a normal stereo 113 A with no switches using the
"ring" connection as a shorting switch to ground.  Since that is DIY OT,
anyone interested in how I did that on my homebrew can e-mail me
privately.  It only added a couple of resistors.
Larry H
2001-03-05 by Dave Hylander
No, The LED is on the output.  I use one of the bicolor and it indicates
the polarity and strength of the signal.  Very similar to the 320 LFO
operation.
dave
>switch is?!?
2001-03-05 by J. Larry Hendry
Now, That's the kind of LED that is valuable.  IMHO.
Larry
Sent: Sunday, March 04, 2001 7:49 PM
operation.
dave
>switch is?!?
2001-03-05 by elhardt@aol.com
 signal, you are adding negative offset. Is that what you meant?<<
I don't think adding a negative offset is the same as adding an inverted
signal which would be like subtracting.  Subtracting is what I was hoping it
will do.
-Elhardt
2001-03-05 by mate_stubb@yahoo.com
Well, Paul also said that two of the inputs will be reversing
attenuators, so yes, it will subtract (add with inverse polarity).
Moe
> mate_stubb@y... writes:
dc
inverted
hoping it
> will do.
> -Elhardt
2001-03-05 by mark@indole.net
I agree.  Although motm doesn't seem big on LED's.
>----- Original Message -----
>operation.
>dave
>>the switch is?!?
which would be silly :)
2001-03-05 by bigd@buffalo.com
We probally wont gte this from Paul, will you mod mine down the road, as im sure
you will yours ?
main complaint people have when they come over on MOTM.... Is this thing on ?  :
hows the weather ?
> operation.
> dave
> >switch is?!?
