MOTM
Funky Rack Rails
Funky Rack Rails
2001-03-06 by bruce@sigalarm.com
So. the MOTM rack rails are not drilled for the same size screw as
regular rack rails.
Paul, other wise ones, care to share what flavor of rack it is for
those lost souls who want to know?
Thanks
Bruce
Re: Funky Rack Rails
2001-03-06 by mate_stubb@yahoo.com
Standard rack rails use #10-32 machine screws. MOTM rack rails use #8-
32 machine screws. The hole spacing is exactly the same for MOTM as
for standard rails. The MOTM panels could probably take a #10 screw
in their corner holes if you insisted on modifying a standard rail to
mount horizontally. BUT, I'd sure try it first, and you should be
aware that you wouldn't have as much slop factor for minute panel
placement adjustments.
BTW, all this information is available if you read the MOTM catalog
online.
Moe
> regular rack rails.
> Thanks
> Bruce
Re: [motm] Funky Rack Rails
2001-03-06 by jwbarlow@aol.com
From a MOTM manual (hardware section) "#8-32 X 3/8"
The hole pattern is the same as a standard rack rail (but you already knew
that).
So if one were to use brass inserts (#8-32) into a piece of pine as mounting
rails, one could use a standard rack rail as a drilling guide I believe.
JB
In a message dated 3/5/2001 7:15:43 PM, bruce@... writes:
>regular rack rails.
Re: [motm] Re: Funky Rack Rails
Shocking!
All three Stooges in agreement!
I guess it helps that it's an empirical question.
JB
In a message dated 3/5/2001 7:37:08 PM, mate_stubb@... writes:
>32 machine screws.
In a message dated 3/5/2001 7:37:15 PM, jlarryh@... writes:
>MOTM screws = 8/32
In a message dated 3/5/2001 7:43:05 PM, jwbarlow@... writes:
Ok.
But back to my original question.  Where does one find the racks or
rack rails that are the smaller #8 size?
Bruce
RE: [motm] Re: Funky Rack Rails
2001-03-06 by Tentochi
8/32 - 3/8"!  Black.
--Shemp
> From: jwbarlow@... [mailto:jwbarlow@...]
> Sent: Monday, March 05, 2001 10:49 PM
> To: motm@yahoogroups.com
> Subject: Re: [motm] Re: Funky Rack Rails
> Shocking!
> JB
> >32 machine screws.
> >MOTM screws = 8/32
You mean other than buying them from Paul? You didn't state your
original question very clearly.
If you want to mount your MOTM in a rack, buy the rails from Paul or
make your own, 'cause you are not going to find commercial rails
tapped for #8-32.
If you are trying to build a wooden case that's wider, your current
choices are to either have a machine shop custom make them from
metal, use a hard wood rail and wood screws, or use a soft wood rail
like pine and use threaded brass inserts.
Moe
> Ok.
> Bruce
In a message dated 3/5/2001 8:07:47 PM, tentochi@... writes:
>Black.
>--Shemp
Troublemaker!
JB
Yep yep...
Have some, use em... thinking of making a much larger place to put the
modules.  Wanted to use the same rails.
Thanks
Bruce
--- In motm@y..., "J. Larry Hendry" <jlarryh@i...> wrote:
> Bruce,
> I have never seen them, other than the one's Paul sells.  Paul's
rails that
> you mount the MOTM modules to are sized to fit a standard size rack
  You
> fasten the MOTM rails (a pair) horizontally in the rack with #
10/32.  You
> attach your modules to the MOTM rails with the 8/32 (supplied by
Paul with
> the module).
> Larry H
> From: <bruce@s...>
> To: <motm@y...>
> Sent: Monday, March 05, 2001 9:57 PM
> Subject: [motm] Re: Funky Rack Rails
> Ok.
> Bruce
2001-03-06 by J. Larry Hendry
Standard rack rail screws 10/32
MOTM screws = 8/32
LH
To: <motm@yahoogroups.com>
Sent: Monday, March 05, 2001 9:14 PM
Subject: [motm] Funky Rack Rails
regular rack rails.
Thanks
Bruce
Bruce,
I have never seen them, other than the one's Paul sells.  Paul's rails that
you mount the MOTM modules to are sized to fit a standard size rack   You
fasten the MOTM rails (a pair) horizontally in the rack with # 10/32.  You
attach your modules to the MOTM rails with the 8/32 (supplied by Paul with
the module).
Larry H
Ok.
Bruce
Well, I guess we were having a hard time following.  At least I was.  One
thing you have  in common
with many of us -- we need a larger space for our MOTM.  :)
Larry H
Sent: Monday, March 05, 2001 10:25 PM
Yep yep...
Thanks
Bruce
> Bruce,
rails that
  You
10/32.  You
Paul with
> the module).
> Larry H
> From: <bruce@s...>
> To: <motm@y...>
> Ok.
> Bruce
