MOTM
California Power and MOTM
2001-03-08 by andy@gooboworks.com
Since I live in California, land of high electricity costs and
brain-damaged politicians, I have this question.   How much power
would a MOTM system use, let's say a 20 module and a 40 module
system?   How would that compare roughly to light bulbs?   Would a 20
module system be comparable to a 150 watt light bulb, more, less?
I run my MOTM through an itty-bitty Danelectro amp, not too good on
the sound but it has such a small footprint.  It seems to me that the
amp (any amp) would use more power than a MOTM.
Thanks
Andy (Clueless EE type)
Re: California Power and MOTM
2001-03-09 by mate_stubb@yahoo.com
Here's an easy seat of the pants calculation you can use:
P = V*I, where P = power consumed, V = voltage, I = current drawn. If
you want to know how much power you are drawing, you would look at
the input side of the power supply, not the output side. That's
because power supplies are not anywhere near 100% efficient, and a
significant percentage of the power drawn gets lost to heat.
So voltage is 120 volts. Without measuring exactly how much current
you are drawing from the wall, you can be sure that your power supply
can't draw more than the fuse allows. My PowerOne supply is close to
twice as powerful as the MOTM-900 (which also uses a PowerOne core).
My supply is supposed to be fused with a 1A fuse, so let's take that
value for argument's sake.
If I was maxing my supply out drawing 1 amp, I'd be drawing about 120
watts. You are probably drawing around 70 watts or less. So it's no
worse than burning a 75W lightbulb.
Moe
Dave's Hot Rod MOTM Shop
http://www.users.qwest.net/~daveb2
--- In motm@y..., "J. Larry Hendry" <jlarryh@i...> wrote:
> From: <andy@g...>
20
> Hey, there a question I know something about, light bulbs.
> The short answer is VERY little.  Less than a 150W lightbulb.
> It seems to me that the amp (any amp) would use more
> power than a MOTM.
> I agree (well, maybe not a "headphone amp."
> Now, if you want to know why power really cost so much in CA, e-
mail me
> privately and I will tell you.
> Larry
Re: [motm] Re: California Power and MOTM
2001-03-09 by John Blacet
Yes, amazingly, the power drawn by a fair size modular is less than the
power needed to *see* it!
Time for those fluorescent bulbs.....
100 Watt solar panels go for about $450, then you need batteries,
inverter......nahhhh! (Yet)
___________________
John Blacet
Blacet Research
http://www.blacet.com
Re: [motm] California Power and MOTM
2001-03-09 by J. Larry Hendry
power than a MOTM.
Now, if you want to know why power really cost so much in CA, e-mail me
Larry
Please refer to answer behind door # 1:
Stooge Larry
then you need batteries, inverter......nahhhh! (Yet)
I say you get one of those stationary bikes and hook a
small generator to it.  Then you can bike your way to
synth bliss.
Larry (who has his own generator) Hendry
