MOTM
Wacky Kovacy cables ...
1999-08-01 by jmw
I received my cables from WackyKovacy yesterday - 20 pcs (12",18" 24", 36")
in various cable/heatshrink color combinations.
He followed my color requests precisely and  even double heatshrinked
(heatshrank?) one length to give me discrete colors - see below... with all
these cables fully patched my MOTM looks like a Rastafarian xmas tree! IRE!
I'm not sure of the brand of cable he uses (he did tell me but I forgot)
but it seems to be a quality product - only 36" cables droop down when
plugged in.
Turnaround was 1 day on the order and at $5 per cable they are a definite
value.
I'll be ordering more as the need arises.
jmw
ps - here's the color schemes that I chose (20 cables, no duplicate colors)
12"  - red cable w/ colored heat shrink (excluding red...)
18"  - blue cable w/ colored heat shrink (excluding blue...)
24" -  Black cable w/ colored heat shrink (excluding black...)
36"  - Black cable as well but w/ white heat shrink w/ a
smaller colored stripe on top of the white.
B/W - Black
B/W - Red
B/W - Blue
B/W - Green
B/W  -Yellow
Re: Wacky Kovacy cables ...
1999-08-14 by J. Larry Hendry
I also ordered some of these cables and I am quite pleased with the result.
 He must measure his length on the pre-connected coax.  A 24" cable is
about 22.5" from top of connector to top of connector and the overall
length including the connectors is about 28."  The same seems to hold true
for the other lengths too.
The cable is identified as "USA-1 High definition instrument cable." The
heatshrink not oly gives color to the cable ends, but also covers the
actual coax to connector jct adding some re-enforcement to one of the the
normal points of cable failure.  You could order the same color black-black
if you didn't want the color.  I used two colors - one for control and one
for signal path (knowing full well these paths may cross...).
I bought 30 cables for $150 plus $15 for priority shipping.  I can't see
spending any time making them at this price. I'd rather be soldering a
module.
Larry Hendry
> From: "jmw" <evening@...>
36")
all
IRE!
> plugged in.
> value.
