MOTM
anyone modded the 120?
2001-03-21 by Cap'n F.M. Bleep
hiya.
i'm curious about the possiblity of modding the 120 so that each sub
octave outputs on a different jack. ideally, the main output jack would
remain functional... has anyone tried this? recommendations? dire
warnings?
bleep.
out.
Re: [motm] anyone modded the 120?
2001-03-21 by Paul Schreiber
Need to buffer the outs. All 4 in a TL074 for $1.
Paul S.
To: "MOTM list" <motm@yahoogroups.com>
Sent: Wednesday, March 21, 2001 3:57 PM
Subject: [motm] anyone modded the 120?
> hiya.
> warnings?
> bleep.
> out.
2001-03-22 by J. Larry Hendry
Yes, I have seriously considered this myself.  I wanted the buffer to have a
little gain in it so the individual outs would be  10 V- peak to peak, or at
least a larger signal than what the 120 outs out now.   The individual
levels now are fixed so that you don't get above 10v peak to peak with
everything maxed out.
One of the great uses for a 120 with individual outs like this would be as a
synth source for the 320 when using the 320 LFO as a sub oscillator.  As it
is today, the 120 output level is a bit too low (my observation).
As Paul mentioned, it could be done cheaply and there is plenty of room on
the panel for the 4 individual outs.  A very small little daughter board
could be made with the four jacks connected to that and then 4 wires back to
the 120 (the pots I think), I'll have to look.
The obvious question is would you still want the pots to control the level,
or would you want the output level fixed like most audio outputs?
When I do the daughter board, I'll put detailed plans up on my web site.
A question for Paul.  On both my 120s, If I have audio IN at A and B, that
are near some multiple of each other, I get some odd pops and clicks at
almost random like times in my mix out when I dial in any sub harmonics.
What is going on there?  Any thoughts?
Larry H
To: <motm@yahoogroups.com>
Sent: Wednesday, March 21, 2001 4:20 PM
Subject: Re: [motm] anyone modded the 120?
Paul S.
> hiya.
> warnings?
> bleep.
> out.
I can't type  --- paragraph 2 line 2 SYNC source... Maybe that makes more
sense.
Sent: Wednesday, March 21, 2001 8:08 PM
Larry H
Paul S.
> hiya.
> warnings?
> bleep.
> out.
