*** MOTM-420 resistor change ***
2001-03-25 by Paul Schreiber
<<<I apologize for sending this to the master list! I of course wanted it sent to the MOTM User's group! now that I launched everyone's email address out there in the open, please let's not abuse that! Arrggghhhh!!!! I'm tired and need that upcoming Mexican vacation *real badly*>> > In some MOTM-420s, the initial cutoff freq, as set by the panel pot, is too > low for the ranges 0-3 ticks. > > What happens is the cutoff is less than 10Hz, so you get DC 'ticks' or as > some user stated a sort of > 'time delay' as you sweep the filter if the FREQ pot os between 0 and 3. > This is because you can't > hear anything out of it (in lowpass mode) until the cutoff is in the audio > range. > > So, there needs to be a resistor adjustment so that 0 tick is not something > silly like 0.2Hz. Rather, it > should be like 20 to 30Hz. > > R9 needs to be *increased* slightly. Currently, it is 221K. I'm going to > start sending kits out > with this resistor to be 255K 1%. Why 1%? just to reduce thermal drift. Now, > that's pretty anal for a VCF! > > The reason your particular '420 doesn't exhibit this is that the 2 2200pf > caps are such that the low end is > around 15Hz instead of like 2Hz. > > If you wish to use a 270K 5%, THAT'S OK BY ME. If you want to add a 22K or > 27K 5% in series with the 221K, > THAT'S OK BY ME, TOO. If you want me to send you free 255K, 1% please just > mail me a SASE. > > You can actually replace this resistor from the top side of the board if you > are careful. I clip the leads as > close to the body as possible, leaving the leads in the holes. I the use > solder wick to remove the solder and > use pliers to grasp the lead and pull it out *gently* while heating the pad.
> I then clip the leads of the new > resistor short after bending, and solder the top pads with all that extra > no-clean solder you have lying around :) > > That's for bringing this to my attention. There is constructive bitching, > then there is just palin bitching :) > > Paul S. > >
