MOTM
Pointer knobs Question
2001-03-31 by Mark
Hi All,
Can these pointer knobs be used to replace the standard MOTM knobs?
Mark
Re: [motm] Pointer knobs Question
2001-03-31 by elhardt@aol.com
modular@... writes:
>>Can these pointer knobs be used to replace the standard MOTM knobs?<<
Yes.  They fit on a standard 1/4" shaft and have a set screw to tighten them
down.  I'm assuming that the rotary switches Larry Hendry is supplying also
have 1/4" shafts.
-Elhardt
2001-03-31 by J. Larry Hendry
Yes, this assumption is correct as I have been using the regular MOTM knobs.
Larry
supplying also have 1/4" shafts.
