MOTM
One more thing - Was: chassis mount MTA-1564??
2001-04-01 by J. Larry Hendry
Oh, I forgot to tell you.  You ony run three wires fromt he PCB to the power
supply.  Paul made the grounds common at the PCB supply.  So you only need 3
conductors between the power supply and the MOTM-900 PCB.  That's another
good reason to keep the wire big.
Larry
----- previous message-------
--Mark--
14AWG is more like electrical supply than electronics supply.
I'll have more choices in three conductor cable than four
conductor cable.
--LH--
4 conductor is getting more common.  New code is requiring a ground separate
from neutral now on many 240 volt appliances (UL caught on to the fact that
these appliances have 120 volt connections.
