MOTM
MOTM w/Syntecno Tee Bee
2001-06-13 by Randallx@bellatlantic.net
Anyone use the Tee Bee to interface with MOTM?  Can it be done? Here
are its specs:
  Four (4) CV/Gate outputs (CV range 0-5 Volt, Gate range
  0-5Volt or 0-10Volt).
  Free selectable MIDI channel for each pair CV/Gate outputs.
  Free selectable Volt/Oct or Volt/Hz for each CV output.
  Free selectable polarity for each Gate output.
  Pitch wheel sensitive CV.
  Sound knobs can control CV of all CV/Gates.
  Polyphone to monophonic selection algorithm.
Any help would be greatly appreciated.
Randy
Re: [motm] MOTM w/Syntecno Tee Bee
2001-06-13 by mark@indole.net
>are its specs:
I've never used a Syntecno TeeBee, but based on the above listed specs, it
should work.  The MOTM-800 responds to positive going gates from 0 to +13V,
and the MOTM-320 and MOTM-300 respond to 1V/Oct.  A Roland TB-303 works
just fine.
