Re: Sequencer input requested
1999-02-02 by Thomas Hudson
Paul Schreiber wrote: > Here is a brief outline of the direction I am going: > > 1) It's modular > 2) Has full MIDI control, but all outputs are analog > 3) Patch memory > 4) I can be BIG. I mean *REALLY BIG* - 256 stages x 64 rows > 5) The modules are tied to a local LAN than reconfigures the modules, ie > Plug-&-Play. > 6) This being MOTM and all, no cheesy pots. We're talking optical encoders, > baby! > 7) uP will be in C programming, with "open source code" posted on the > website. Okay, I've given this some thought. I would a sequencer that supported downloadable "personalities." For example, I may want to read from the ADC and select a stage according to voltage, i.e. voltage control stage select. I may want to play with random numbers or markov chains, e.g. set up probabilities for each stage based on previous stage, etc. One interesting idea is to be able to download code via midi. I nibblize my program and pack it in a sysex message and when sent to the device it gets flashed to ram. Imagine people posting new "personalities" to the web. Could really drive sales. I might still like to have a parallel or serial port to drive it directly from my PC without going thru midi. Especially if this is bi-directional. If I could use the knobs on the device to drive software on my computer this would be an extremely important new "personality." It's a sequencer, no it's a programmer, no it's MOAS! Oh yeah, fast enough to do waveform generation. So it's a wavestation too. Another important feature would be to use a uP that is supported by GCC (the GNU C compiler). Setting up GCC as a cross-compiler to run on unix or windows is fairly easy. I'd be willing to help on this. This gives everyone free tools to program with. GCC tends to work better with 32 bit or higher processors, but I believe some MIPS chips can be had for as little as ten dollars each. I'm not sure what <32 bit uP are supported by GCC, I can look into this if there's interest. Here's a short list of supported platforms: http://www.cygnus.com/gnupro/gnupro-platforms.html The MOAS could be the center-piece of the studio with these features. Think of the possibilities. With 128 stages I could use my computer to read midi from my keyboard and thru the parallel port select stages, now I have a midi to cv converter that supports microtonal tunings and just intonation. Just some thoughts, Thomas
