Why would anyone do that??
2001-07-16 by Tkacs, Ken
I have a question about a possible mod to the MOTM-101 Sample & Hold that is probably going to make Paul scream. This would be for us "Mort Subotnick" / "Forbidden Planet" heads. Obviously tremendous attention has gone into this module in design and parts selection to minimize 'droop.' But would it be possible to add a "Droop" control? You know... at zero it does nothing, but increasing the value allows the held voltage to "fall off" more quickly? Is this as simple as a pot and resistor in series between ground and one side of C16? On a side nore, SW1 is noted in the schematic as being "On Panel," but it's actually a jumper. Was there an electronic reason that this was excluded from being a panel control...? Or was it a space issue?
