MOTM
Re: [motm] The NEXT thing (ribbon controller)
2001-08-17 by mate_stubb@yahoo.com
I disagree slightly with Stooge Barlow on a couple of points.
1. The Moog ribbon controllers have two narrow metal bands that run
the length of the ribbon, slightly to one side. You bridge the gap
between the tracks anywhere along its length to generate a gate. I
like the option of generating gates manually instead of
automatically. Maybe Barlow and I could compromise and have a mode
switch that handles both.
2. The single most important useability feature would be to adopt the
Yamaha convention of having the zero point be where you first put
your finger down. That way you can touch down anywhere on the ribbon
and do finger vibrato, or smooth sweeps away from the current control
voltage. You could have another mode switch that allows it to operate
the other way as well.
Moe
I also think gate and trigger should be generated with each touch of \
the ribbon.
Two things which I'd add as ideas are: 1) a rotary (Paul gasps) range
switch to reduce the range to as little as one octave. 2) a scale
switch to cause the mid point of the ribbon to generate zero volts
with the right side positive, and the left side negative.
2001-08-17 by The Old Crow
  For those interested, here is how Yamaha did this:
http://www.cs80.com/csribbon.gif
  They just detect when the ribbon is touched and store the initial ribbon
contact voltage on an S/H cap.  Part of this circuit shows the coarse/fine
tuning knobs used on a CS.  The output drives the top end of the DAC
'octave' resistor ladder in the CS.  Modular use would just need the
output scaled for +/-5V or whatever.  I am unsure what the ribbon
resistance is, but that should not be too critical.  I'll measure it the
next time I have the CS-80 open.
  Oh, the 'down' and 'up' gates can be picked off those comparators and
buffered for gate/trig use.
Crow
2001-08-17 by moog@buffalo.com
I would investigate the use of tactex if you go this direction.  This seems like
a great prospective product for this type of apllication.  I know a few other
MOTM users are  looking to get the new moog synth to control there motm's just
because of the of that tactex pad and others reasons Im sure too.
Jim
> Moe
> the ribbon.
RE: [motm] The NEXT thing (ribbon controller)
2001-08-17 by Brousseau, Paul E (Paul)
I hate "me too" posts, so I'll say "ditto" instead.  :)  But seriously, a
Tactex box with CV breakouts would be faboo.  I wonder if the Tactex people
would consider making a ribbon-shaped controller as well?
(Appologies to Jim for sending this twice...)
--PBr
Sent: Friday, August 17, 2001 6:21 AM
To: motm@yahoogroups.com
Subject: Re: [motm] The NEXT thing (ribbon controller)
like
other
just
Re: [motm] Re: The NEXT thing (ribbon controller)
2001-08-18 by imorpheusl@aol.com
<controllers. For controlling a modular they seem kind of lame.
I've always envisioned a disc-shaped surface with zones that were
both sensitive to impact and pressure.
Imagine a circular controller divided into 8 pie-slice shaped zones.
Tapping with finger sends a gate/trigger pulse. Sliding a finger over
a zone while pressing down sends a varying control voltage.>>
Could you use a korg kaoss pad and a kenton pro 2000 to get this effect? I'm
not sure how extensive the kaoss pad's midi is but it could be pretty damn
cool. Imaging running 2 420's, one set to HP and the other set to LP and
using the kaoss pad to change the cut off frequency. Ultimate band pass
filter control :P
-Chaz
2001-08-18 by moog@buffalo.com
Midiman has the control one coming out soon designed by MOTMer Tony .K
I have a picture of it if someone can post it on there website, let me know.
JIm
imorpheusl@... wrote:
> <<It's good to see talk about alternatives to keyboard-based
> filter control :P
> -Chaz
>                    Yahoo! Groups Sponsor
>                        ADVERTISEMENT
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2001-08-18 by Dave Hylander
I still have the pic you sent me and I'll put it up, and send the link.
>JIm
The Midiman Surface One controller:
http://www.hylander.com/images/motm/surfaceone.jpg
>JIm
2001-08-18 by jwbarlow@aol.com
In a message dated 8/16/2001 8:46:13 PM, mate_stubb@... writes:
That's because you're slightly wrong<g>!
This is a good idea! I'd prefer to have the option of generating a
gate/trigger with each touch of the ribbon, but also be able to
"re-gate/trigger" with an additional button (or pad). I wouldn't want to
always have to use a separate button (or pad) to generate the gate/trigger.
Good compromise Moe!
I remember this being mentioned before. Thanks to Crow for posting the info
about it. This would be a good feature, but again, I wouldn't *always* want
the ribbon to operate like this. Maybe a few operating modes would be useful:
1) "traditional" style, 2) zero set (Yamaha style), 3) zero at mid point.
Additional scaling (inverting) and offset switches and pots could be added to
these modes, as well as ways to make the output vary from linear to
exponential.
And it might be good to have controller body marked with position markers too.
JB
