MOTM
Re: [motm] MOTM Patch Sheets (Version 7)
2001-08-22 by elhardt@aol.com
Assuming that picking the Version 7 option in the SaveAs dialog box works,
then I now have the MOTM modules in Corel Draw version 7 format.  They can be
downloaded from the link below.  The same rules apply for printer scaling as
a previous post described.  However you can change the size of the page and
printer settings to do whatever you want.  I should also mention that I use
the two following fonts just incase you need to install them from your Corel
disk.
Swiss911 XCm BT
Swis721 Cn BT
http://members.aol.com/isobarb8/motm7.zip
-Elhardt
Re: MOTM Patch Sheets (Version 7)
2001-08-22 by Mike Marsh
Could you save them as WMF files?  That way, pretty much anything can
import them and you preserve vectorness...
works,
They can be
scaling as
page and
that I use
your Corel
> disk.
> Swiss911 XCm BT
> Swis721 Cn BT
> -Elhardt
2001-08-22 by mate_stubb@yahoo.com
Thanks, that did the trick!
Moe
works, then I now have the MOTM modules in Corel Draw version 7
format.
Re: [motm] Re: MOTM Patch Sheets (Version 7)
mmarsh@... writes:
import them and you preserve vectorness.<<
I'll give that a try tomorrow night and see how it works.  I hope it
preserves line thinkness, text spacing, curved surfaces and other stuff,
otherwise they are going to get pretty messed up.  I'll still do the JPG's
too for those only with paint paint programs.
-Elhardt
