MOTM
[motm] Module Patchsheets in JPG and WMF
2001-08-24 by elhardt@aol.com
Below are links to the MOTM module patchsheets in JPG and WMF formats that
people requested.  I read the WMF format back into Corel Draw and it looks
almost as good as the original, most likely providing you have the couple of
fonts listed below or something similar.  So I hope it works out.  And the
JPG is just one big image of the modules at a scale of 72 dpi.  Since I don't
know if the intent is to print them on a printer or just to display them on
the screen, they are reasonably large now and can be scaled down if needed.
Or if you prefer the modules to be separate files that you can open one at a
time and cut and paste, then you will have to cut each module out and save it
as a separate file yourself.  Links below.
Fonts Used (only applies to WMF format):
Swiss911 XCm BT
Swis721 Cn BT
http://members.aol.com/isobarb8/patchsheet.jpg
http://members.aol.com/isobarb8/patchsheet.wmf
-Elhardt
Re: [motm] Module Patchsheets in JPG and WMF
2001-08-24 by Microtonal
Thanks!!!  The jpeg file looks great!
John Loffink
microtonal@...
To: <motm@yahoogroups.com>
Sent: Friday, August 24, 2001 4:26 PM
Subject: [motm] Module Patchsheets in JPG and WMF
of
don't
on
needed.
a
it
> Swiss911 XCm BT
> Swis721 Cn BT
> -Elhardt
Re: Module Patchsheets in JPG and WMF
2001-08-24 by Mike Marsh
The WMFs look very good.  Thanks!
formats that
> people requested.  ...
