FW: [motm] [ot]Need more graphics help
2001-12-09 by Tkacs, Ken
I'd be glad to take a look at this (and your Corel issues) when I get to work on Monday, assuming no one solves them earlier. In general, the outline method is preferable--you outline your areas and then fill them. If you use a "centerline/width" approach, you can get all sorts of wacky results when porting graphics. Of course, I'm speaking of general graphic stuff, and you have a specific issue, so it may not exactly apply.
-----Original Message----- From: Paul Schreiber To: MOTM listserv Sent: 12/08/2001 10:17 PM Subject: [motm] [ot]Need more graphics help I have uploaded 2 file versions (TIF and BMP) of the logo to www.synthtech.com/pix. I need a DXF version, that is "solid". When I try, I get just the outline (?) The 'X' dimension (longways) needs to be 1.75 inches, the 'Y' whatever for aspect ratio. I want to put the logo on the MicroModule pcbs, and DXF is the only file I can Import. Paul S. Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
