Re: [motm] Comparators
2002-02-14 by Scott Juskiw
At 8:48 PM -0600 2002/02/13, J. Larry Hendry wrote: >Here is the idea: Feed the gate signal into the VC lag. Set the down lag >time for zero. Take the output and run to 3 comparators. Each comparator is >set to turn on its output at a progressively higher level. The output of >each comparator is used as the delayed gate. So, now I have 4 gate signals >turning on a 4 different times - the original gate, and the 3 comparator >outputs. The up lag time sets the overall delay range. The comparator set >points set the relationship between gate times. Since the 820 is set for lag >only in the up position, all gates would end at the same time. You can sort of do this will a few 700s. Plug the 820 outs to the 700 CV ins. Plug a DC bias into the IO A/C inputs. Plug nothing into IO B/D inputs. Set the thresholds to different values to get delayed gate outputs. >The more I think about comparators, the more useful I see these generic and >apparently useful utility circuits. I guess I am surprised that more people >on the list have not talked about them. I'd like to see some kind of comparator functionality in a future module. With thresholds for both the up side and the down side (sort of like adjustable hysteresis). These thresholds would be voltage controllable, of course.
