MOTM
Ignore last, real answer
2002-03-11 by Paul Schreiber
Sorry!
a) 3/32" is what I mainly use
b) The power supply uses 1/8" and 3/16" The 3/16 is special: it is 3:1 shrink rate instead of 2:1
AND it uses UL-approved heat-release adhesive coated tubing. As it shrinks, the "hot-melt glue"
forms a water-tight barrier. This is NOT needed on other modules.
And PLEASE use a heat-shrink gun! No Bic lighters :(
Paul S.
RE: [motm] Ignore last, real answer
2002-03-11 by Bob K
If you don't have a heat-shrink gun, like myself, holding a soldering iron a
few millimeters away from the tubing does the same job.
But I guess we all probably know that.
so... nevermind.
-Bob
Sent: Sunday, March 10, 2002 11:51 PM
To: MOTM listserv
Subject: [motm] Ignore last, real answer
Paul S.
_________________________________________________________
Do You Yahoo!?
Get your free @... address at http://mail.yahoo.com
