700F. I don't need the extra credit, I got a 100 average.
Paul S.
To: <motm@yahoogroups.com>
Sent: Sunday, March 17, 2002 1:02 PM
Subject: [motm] Ideal Soldering Temp?
> Hey All -
> What's the ideal soldering temperature for building MOTM kits? And
> in degrees centigrade for extra credit.
> Mike
On Sun, 17 Mar 2002, mmarsh100 wrote:
> Hey All -
Soldering ICs and small parts, 600F ~= 315C
Soldering larger parts, wires to jacks, etc., 700F ~= 370C
SMD solder, hot blowgun set to 960F ~= 515C
DE-soldering, I set the vacuum tool to 752F = 400C for most stuff.
General rule, if the flux is boiling, the tip is too hot.
Crow
Yes, but I grade on a curve :)
I've been using 330C which has worked. Old Crow wrote directly that
he uses about 315C for ICs and small parts and 370C for large parts.
I guess I'll up my temp some for larger parts.
Larry made mention that I might be using the wrong temp because I had
so many errors (mostly cold solder joints) in my 822. Hence the
question.
Thanks to all who replied!
Mike
> Paul S.
> From: "mmarsh100" <mmarsh@s...>
> To: <motm@y...>
> > Hey All -
And
> > Mike
Jumping in late...
>question.
What kind of solder were you using? Some alloys may not melt easily with a
600 degree tip.
I've yet to damage a *decent* PC board or a component with a 700 degree tip.
Terry Bowman, KA4HJH
"The Mac Doctor"
"There is no Main Street anymore except at Disneyland--and try and buy a
gun there"--Hank Hill
