MOTM
Stooge panel invoices
2002-05-09 by J. Larry Hendry
If you have not received your Stooge invoice yet, there is a good reason.  I
have not sent any out.  I am waiting until I have most all the orders
together and will do it all in one bunch.  So, fear not, I have not missed
your order.
And, it has been one of "those" weeks at work.
Larry
2004-04-15 by J. Larry Hendry
Many of you have noticed that you have not yet received your Stooge panel
invoice.  Fear not.  You orders are all in good order.  However, I have been
very busy with my regular job and I simply have been unable to organize
that.
Also, some of you when you ordered your panels said, "and brackets for each
one."  While that may sound trivial, it does mean I have to sort through
your projects and determine what bracket is best.  What I plan to do about
that is start a "which bracket should I use for this module" web page to
make it easier for everyone involved to figure that out.
Some of these modules however, I have not built.  So, once I put down all
the ones I know, I will be leaning on some of you expert builders to advise
me on the ones I have not built myself.
I'll get the invoices out ASAP.
BTW, I have flat rails from the metal shop.  They cannot go to powdercoat
until I get all the screws stuck in them.  It's on my "to do" list.
Stooge
Larry
