MOTM
MOTM-120
MOTM-120
2002-06-06 by Graham Hunter
The MOTM-120 has been sold.  Thanks to everyone who inquired.
Graham
Do You Yahoo!?
Yahoo! - Official partner of 2002 FIFA World Cup
http://fifaworldcup.yahoo.com
MOTM-120
2005-05-18 by Tom Adam
I was surfing the net a bit and stumbled over this link:
http://www.techman.synth.net/techman_website2_00002e.htm
copy:
"When it came to testing this module, I was a little perturbed that it
didn't work as I expected. in sub mode, turning up each of the four sub
octave pots produced glitches in the audio if I had signal on both the A
IN and B IN jacks. This couldn't be right. ... This time I happened to
put the scope probe on the non-inverting input of the input comparator,
and lo, the glitching stopped. Aha.. the capacitance of the scope probe
had stopped the clock jitter. Solution: I happened to have a couple of
18pF ceramic caps handy, so I put these across the non-inverting input
and ground (Pins 2 & 1) of both of the 311 comparators. Problem solved.
The module now appears to work as intended...."
Since I was experiencing the same problem, I tried it out.  I needed to
take apart the whole module to be able to fit the caps, but the result
is very nice. Now I know what a MOTM-120 should sound like. Very cool!
Tom
Re: [motm] MOTM-120
2005-05-18 by Richard Brewster
In the SUB mode it should not matter what is going to input B at all.
The B input should be ignored.  Why would eliminating "clock jitter" on
the B input make any difference?  It seems to me this has little to do
with what mode the 120 is in, because in the scenario described there
are inputs on both A and B, and the solution is to modify both comparators.
Paul, what is your take on this modification?
-Richard Brewster
>copy:
>Cheers,
>Tom
Re: [motm] MOTM-120
2005-05-18 by eric f
Weird... I'm having this problem too... Thanks for posting this!
cheers,
eric f
copy:
Tom
Yahoo! Groups Links
   To visit your group on the web, go to:
http://groups.yahoo.com/group/motm/
motm-unsubscribe@yahoogroups.com
Re: MOTM-120
2005-05-19 by bootlegsounds
I had a request regarding the 120 - maybe someone else was thinking the same. Would it
be possible to get some samples of what it does in terms of just adding the sub-octaves?
I know, it's a boring request, but while it's nice to hear what it's theoretically capable of -
full-on intermodulated extremeness - for my purposes it'd be much more useful to know
what it sounds like when *just* adding the sub-octaves.
Some of you might say "it sounds like the original, but with four sub-octaves" but there
are sub-octaves and there are sub-octaves, if you know what I mean.
just my 2 cents,
Matthew
> copy:
it
sub
the A
to
comparator,
probe
of
input
solved.
needed to
result
cool!
> Cheers,
> Tom
Re: MOTM-120
2005-05-20 by djbrow54
> thinking the same. Would it be possible to get some samples
Not exactly to your request but I do have one sample of using
the MOTM-120.  I have the Tellun mod and I use the mix out to
drive the CV's on my VCOs.  I run them through a quantizer first
and then tweak the knobs until I get a pattern I like.  There
is one on my samples page - "The Journey"
http://modularsynthesis.com/samples/samples.htm
"Happy" and "Delirious" are very similar only I am using my
PSIM to generate the dividers and I don't use binary (e.g.
divide by 3,5, etc.).  Again, you just tweak the mix until
you get a pattern you like.
I also added the 100 pF caps to clean up the crosstalk.  It didn't
completely eliminate it but it made it significantly better.  It
now only occurs at above audio frequencies.
