MOTM
Granular Synthesis on MOTM
2002-07-12 by mmarsh100
Hi All -
Just back from vacation.  Two weeks away from all musical tools is a
recipe for epiphane, albeit a painful wait to try things out.
Here is a way to do basic granular synthesis using only four
modules: two oscillators, on EG, and a VCA.  For theory check out
Curtis Roads' "Microsound" from MIT Press.
Oscillator one is set at 20 Hz to about 800 Hz (between about 2 and
4.5 on the COURSE knob) and will output pulses in the 10 to 50 msec
range (you do the math, I suck at it).  The PULSE output is sent to
the GATE or TRIGGER in of the EG. The EG's DECAY and RELEASE are set
to zero with ATTACK and SUSTAIN set to about 2.  The + OUT of the EG
goes to a 110 CV IN.  Another oscillator's SIN out is sent to the
110's IN (this is the signal to be granulated).  Send the out to the
console, but if you have a scope send it there, too.
Play with the COURSE knob on oscillator 1 and the ATTACK and SUSTAIN
values on the EG.
What's happening is that we are 'granulating' the output of the
second oscillator.  Each granule has it's own little envelope but is
played at a rate below which we can detect pitch.  Taken together
the grains create a new timbre and texture.
Cool!
Try feeding ANYTHING into the IN of the VCA (guitar, vocals, drum
loops, sequences).  Paul suggested MiniWave, which is a great idea...
Mike
PS - Paul, the 700 doesn't work as well for 'chopping' as you put
it, because the 'envelope' in AUDIO mode is fixed at 5 msec which is
not that usefule in granular synthesis.  Makes a cool weird noise,
though!
m
Re: Granular Synthesis on MOTM
It's worth looking at these in a waveform editor.  You can see that
each little granule has it's own envelope...
Mike
--- In motm@y..., "Paul Schreiber" <synth1@a...> wrote:
> Sound examples are at:
> http://www.synthtech.com/demo/new
> Paul S.
Re: [motm] Granular Synthesis on MOTM
2002-07-12 by groovyshaman@snet.net
Very cool Mike.  Hmmm...I wouldn't be surprised if the MP3 encoding process
loses some of the detail and therefore the timbre is a bit off.  (I guess
this could be checked by playing the mp3 through the scope.)  This is a good
starting point for more complex sounds.  Did I hear some Time Machine in one
of those clips?  That one sounded wack.
George
To: <motm@yahoogroups.com>
Sent: Friday, July 12, 2002 2:08 PM
Subject: [motm] Granular Synthesis on MOTM
> Hi All -
> values on the EG.
> Cool!
> Mike
> though!
> m
Yes, that was TM - good ear, George!  MP3s are kind of a pain, but
they are easy to distribute.  I think there are phase prblems with
MP3s.  There is a plug-in that corrects this somewhat but I haven't
laid out the cash for it.  I think of it as a Xerox copy of the
original.  Enough info to give you an idea but not good enough for
formal publishing.  Doesn't stop some, though, does it?  :)
Mike
encoding process
(I guess
is a good
Machine in one
> George
> From: mmarsh100 <mmarsh@s...>
> To: <motm@y...>
> > Hi All -
is a
and
msec
to
set
the EG
SUSTAIN
> > values on the EG.
but is
> > Cool!
idea...
> > Mike
which is
noise,
> > though!
> > m
2002-07-13 by michelhav
Hi Mike,
Thanks for your interesting 'granular sound' tip. I noticed that if
you choose the GATE IN on the EG instead of the TRIG and increase the
pitch of oscillator one, you get a different, heavier distorted
sound. But listening to the demo's I think you already found that
out...
Michel
--- In motm@y..., "mmarsh100" <mmarsh@s...> wrote:
> Hi All -
a
set
EG
SUSTAIN
> values on the EG.
is
> Cool!
idea...
> Mike
is
> though!
> m
2002-07-13 by mmarsh100
Hi Michel -
I'm still trying to understand this one, too!  Further experiments
revealed that if you change the duty cycle of the pulse, you get a
different timbre.  Also curious: if you use both GAT and TRIGGER you
get no sound at all!
Did you hear #8?  That was a mono chord from a synth into
4 'granularizers' spread in a wide stereo field.  Really cooL!
Mike
--- In motm@y..., "michelhav" <anymail@x> wrote:
> Hi Mike,
if
> out...
> Michel
> > Hi All -
is
> a
out
and
msec
to
> set
> EG
> the
> SUSTAIN
> > values on the EG.
but
> is
together
> > Cool!
drum
> idea...
> > Mike
put
which
> is
noise,
> > though!
> > m
Re: [motm] Re: Granular Synthesis on MOTM
2002-07-13 by rogers t
--- mmarsh100 <mmarsh@...> wrote:
 if you use both GAT
> and TRIGGER you
Did your try using the TRIGGER on the GAT?  Usually
that makes lots of noise.
Got any GITTENS?
tom
Do You Yahoo!?
Yahoo! Autos - Get free new car price quotes
http://autos.yahoo.com
