MOTM
VCO CV mixer
VCO CV mixer
1999-03-05 by Paul Schreiber
Err.....Chris is wrong on this one.
The MOTM-300 has 3 CV inputs: 1 unscaled 1v/oct, 1 [FM1] that if set to EXP
can be scaled up to 1.5V/oct (for that irratating EML crap) and FM2 that can
be
also scaled up to 1.5V/oct.
So, you plug your trusty Pro2000 into the 1V/oct input, and the other 2 are
for LFOs, S&H, etc.
Paul S.
Re: VCO CV mixer
1999-03-09 by Lindberg, Niklas
Hi!
While reading this once again with a little more thought,
I got a little puzzled by these 1.5V/oct...
Sure you didn't mean 1.5oct/V? :)
I mean normally you can attenuate a CV input down (CCW) to almost
infinity V/oct and on the other end (CW) up to a 1:1 relation with the
input CV...
This also leads me to a question... what figure (V/oct) do you get when
turning the FM attenuators max CW?
The reason I ask is if you want to create a real fast, snappy frequency
sweep
using an EG (a' la Kraftwerk percussion) you only have 0-5V CV span from
the EG, and that would give you 5 octaves sweep using a 1V/oct input...a
little to little IMO.
I know this isn't really a problem as you can rescale the inputs to your own
taste by choosing a different summing resistor value, but I'm still
curious...
/Niklas
 >  Niklas Lindberg                                   >
<   Analogue Synths & Electronics Freak              <
<     "The availability of a certain patchcord       <
 >	    is inversely proportional to its need"         >
 >       _                              Anonymus      >
<_______/ \   _______________________________________<
           \_/
> From:	Paul Schreiber [SMTP:synth1@...]
> Sent:	Friday, March 05, 1999 4:21 AM
> To:	motm
> Subject:	[motm] VCO CV mixer
> From: "Paul Schreiber" <synth1@...>
> EXP
> can
> be
> are
> for LFOs, S&H, etc.
> Paul S.
> Ta Da! Come see our new web site!
> http://www.onelist.com
> Onelist: A free email community service
