MOTM-450 it is
2002-09-02 by Paul Schreiber
It think a "stand-alone" MOTM-450 is best. This keeps off the digital switcher "noise", is the same format (read: I can use the same sheet metal design) as the MOTM-900, and allows for 500 Series only users not forced to buy 2 supplies. The 2A on the +5V is sort of "whimpy". But I will make a MOTM-980 Distribution board, so you can buy a larger supply. Power One has these "Triple output" supplies in all sorts of sizes, same as the dual one I'm using now. The model number I'll be using is HTAA-16W-A. Paul S.
