To: "MOTM List" <motm@yahoogroups.com>
Sent: Monday, September 02, 2002 2:33 PM
Subject: Re: [motm] MOTM-950 it is
> > From: Paul Schreiber <synth1@...>
> > It depends on the power jumper board. Let's see if I have room for say 3
> 4-pin MTAs on it.
> --LH--
> Why not keep the curent standard wiring for the same 4 center pins on the 6
> pin connector? Put the 5 volts on one of the outside 2 pins. Then, that
> power supply need only have one type connector (the 6 pin MTA). The 4 pin
> connectors could still attach with an unused pin sticking up on either side
> of the 4 pin connector. If I am not mistaken about the pin spacing and
> size, it looks as if the 4 pin cable could still easily plug on to the 6 pin
> connector if you wanted to have only one style connector on the new PS.
> Larry H
