FS: Mini-Moog, SH-101, SDE330, Drawmer 1960, 707, etc.
2002-10-16 by media.nai@rcn.com
Mini Moog Model D w/Calzone flight case $3000
Stunningly beautiful cosmetic condition.
Everything works perfectly. Recently tuned and calibrated.
This is an early Mini with the original "phatter" oscillators.
All original knobs and switches. Flawless graphics.
Contains modification designed by Bob Moog for 1V/Oct external control.
This mod uses much better parts than the Moog itself, including
a Switchcraft jack and high-quality C&K switch. It's completely hidden
from the front panel, and does not alter the synth circuitry in any way.
No signs of wear except hairline fractures in two adjacent keys.
Includes custom Calzone flight case, S-trigger cable,
and external gate to S-trigger converter.
Drawmer 1960 $1400
Valve hybrid using 12AX7 tubes. Near perfect cosmetic condition.
Combination instrument pre amp (with EQ), two channel mic pre,
and two-channel compressor with link, sidechain, and inserts.
Best revision -- later VCA's, with earlier tube amplifiers.
Switchable attack and release, with 3-way analogue meters.
Includes manual. Sorry, I don't have the original box.
Roland SH-101 $400
Blue. Includes mod grip, and installed Kenton mod for external
control of mod depth and VCF cutoff. Works perfectly except that
the switch on the bender for mod is broken -- easily repaired,
but I never fixed it because the bender still works, and it is
unnecessary with the either the mod grip or the Kenton mod.
Has cracks around the Kenton jacks (I bought it that way)
that have been repaired. I tried adding the "NovaMod" external
LFO sync but it didn't work, luckily I tested it before I drilled
a hole for it. Includes spare "white dot" CEM3340 VCO chip that
is no longer available -- hand selected by Roland for the SH-101.
Photocopy of service manual available on request.
Roland SDE-330 $350
True stereo digital delay using RSS 3-D technology.
Exceptionally warm clean sound. Unique spatial animation.
One of the few DSP boxes that seems to be going up in price.
Excellent flanger. Includes pitch shift, non-linear, and reverse delay.
CV input. Balanced TRS connectors. MIDI control. Syncs to MIDI clock.
Includes original box, both manuals, and photocopy of SysEx spec.
UREI 539 Room EQ $300, pair
27 band graphic EQ with high and low pass filters.
Switchable. Adjustable gain with LED indicators.
Beefy 2U professional unit with balanced barrier strips.
Worn cosmetic condition, but work perfectly.
Price is for a pair of two mono EQ's.
Roland TR-707 $100
100% mechanical condition, 100% electronic condition.
Looks great!! Price does not include manual or wall wart,
but I will go copy the manual for an additional $20.
(well, that's what Roland would charge you :)
Niche ACM $100
Eight channel MIDI controlled mutes and faders, or 8*1 mixer
Box, manual, flawless, serviced by the engineer who designed it.
Ibanez MS-10 Metal Charger $50
Five knobs, huge sound, pretty for a pedal.
TERMS: Prepay or Paypal, Buyer pays shipping.
Sorry, U.S. buyers only.
All prices U.S. dollars.
CONTACT: media.nai@...
My ISP has changed my address:
media@... is now media.nai@...
media@... is media.nai@...
Please make a note of it, Thanks!! :)
