MOTM
Re: Canare Cable...
Re: Canare Cable...
2002-10-24 by Dave Garfield
Hello, all!
OK - My two cents.  Canare cable.  Back when I was a 'hero' Second
Engineer at Skyline Recorders in Old Topanga Cyn. in Southern California,
we upgraded our cables to accomodate Bob Dylan for his "Knocked Out
Loaded" album.  We went from some standard Belden co-ax to shiny, new
Canare Quad cable, where you get a twisted pair each for the Hot & Cold
lines (and braided shielding, too).  I was in charge of assembling these
cables, since I was the only one with enough soldering/wiring experience
to do so.
Wiring the cables was easy.  Instead of a single wire to the Hot or
Cold, a twisted pair was soldered to the terminal, and covered with
heatshrink tubing.  The wires in each of the twisted pair were very fine,
supposedly suitable for transmitting high frequencies, and the shield
weaving was robust.  Everything was insulated with heatshrink, the cables
were color-coded as to their length... a Pro-fess-ional job, if'n I do
say so me'self.
We did an A/B comparison with some of our old mic. cables and the new
Canare ones, and the difference was noticeable.  The Canares were
"half-a-hush" quieter (Due to the twisted pair leads for each of the signal
paths, I believe) than the old stuff.  While I won't go as far as saying
that Monster Cable is far superior to Rat Shark 16-gauge zipcord, I can
say, with impunity, that my ears heard a tangible difference in the
quietness of Canare cable, compared to the old Belden mic. cables.
At the time, the Canare stuff cost us the ass-tronomical price of $300
(mid-'80's) for about 100 ft., but it was worth it.  I'm a BIG
supporter of the Quad (?) cable, after that.
As I said, my two cents...
     Dave Garfield, synthead
PS - Paul, You 'de MAN!!
Do you Yahoo!?
Y! Web Hosting - Let the expert host your web site
Re: [motm] Re: Canare Cable...
2002-10-25 by elhardt@att.net
Just some comments:
Thanks Roger T for the single wire Canare tip. When you mentioned guitar cable
it jogged my memory and that was what Canare cable I was trying to track down
in the past.
As for using two line cable for patchcords, it seems like one should use what
fits job, and that would be single wire. I use a cable stripping device that
has two blades. It can strip the outer rubber portion and about a half inch
over it strips down to the inner wire. So in one shot I'm ready to start
soldering. It's a great time savings device and makes it a lot nicer to make
your own cables. It's not going to work on two line balanced cable. Not to
mention that I've seen some balanced cable that doesn't bend/droop naturally
and/or has a bit of a lumpy shape because of the twisted pair inside.
As for cutting down on noise. Maybe in a studio situation where you're running
long cables, but then again, that's what balanced lines is used for. For
patchcords it probably won't make any difference.
-Elhardt
2002-10-25 by J. Larry Hendry
And that tool was purchased where?  Details please.
Larry
I use a cable stripping device that has two blades. It can strip the outer
rubber portion and about a half inch over it strips down to the inner wire.
So in one shot I'm ready to start soldering. It's a great time savings
device and makes it a lot nicer to make your own cables.
Re: Canare Cable...
2002-10-25 by strohs56k
--- In motm@y..., Dave Garfield <daveogarf@y...> wrote:
> [...] While I won't go as far as saying that Monster Cable is far
> superior to Rat Shark 16-gauge zipcord, I can say, with impunity,
> that my ears heard a tangible difference in the quietness of
Apparently star-quad does really well is in "live sound" applications
(like sound for film or video) where you have mic cables in the
presence of high EMI (phase control lighting dimmers running thousands
of watts of lighting or whatever.)  As in - it is pretty good at
rejecting this type of noise.  As such, it makes sense that the cable
would also be quiet in less demanding environments.  However, this
really only applies for balanced interconnect.  So as Elhard suggests
- for the unbalanced signals on a modular synth, overkill!  It is very
nice cable though :)
