MOTM
+5 Connector Final Answer Is?
2002-10-27 by emmaker
Paul,
Either I missed it or it's not there. Did you come up with the final
solution for a digital +5V connector on the MOTM boards?
Thanks much.
Jay S.
Re: [motm] +5 Connector Final Answer Is?
2002-10-27 by Paul Schreiber
There is no "+5V connector".
Rather, the new modules use 6-pin MTA-156 connectors, with new 6-wire power cords and a new
MOTM-950 power supply.
If you are in a large cabinet, you can also buy a stand-alone +5V 6A supply from Power One and
wire in into the new MOTM-980 connector board. Then using the existing supply for +-15V.
For new cabinets, there are several Power Ones with "Triple Outputs"  (I use the CP-131A).
Paul S.
To: <motm@yahoogroups.com>
Sent: Sunday, October 27, 2002 4:19 PM
Subject: [motm] +5 Connector Final Answer Is?
> Paul,
> Thanks much.
> Jay S.
