MOTM
Re: digital source and its medium puzzle- the answer
2002-11-06 by ringmod45
Okay, a few people are going to say I am nuts for saying this, but
it`s one of the major reasons for some of its inefficiencies.
THE DISCS ARE NOT PERFECTLY ROUND.
When the discs come out of the factory, they look round,but they are
far from round. This creates a push-pull wobble effect.
I have done blind listening tests with the same discs. One of them is
the factory version and the other is a perfectly round bevelled disc.
I heard information on the bevelled disc which was missing from the
factory disc. Don`t believe any of the AudioFools who say it doesn`t
make a difference. Any person who can hear properly, can spot the
difference right away. It`s amazing, that the manufacturers let this
happen in the first place. Even AudioFool CD`s aren`t bevelled.
The reason, I didn`t answer this question more quickly, was that i
couldn`t find the website for you to see for yourself. The bevelling
machine comes from Germany.
There are DAC`s out there, that don`t use any filtering whatsoever.
Please check out the URL below.
http://www.sakurasystems.com/articles/pitracermemo.html
This is a Japanese company, which is way ahead of the game. Instead
of fixing the Digital to Analog converter with filtering and
oversampling, they choose to attack the problem at its source. They
keep parts, in the units, down to the bare minimum to get the job
done.
RM
Re: [motm] Re: digital source and its medium puzzle- the answer
2002-11-06 by Neil Bradley
Either the data is read correctly or it isn't. Data is buffered as much as
a second ahead of where it is with plenty of time to recover. If you have
exactly the same data with no buffer underrun, wobble or no wobble, it
will make no difference.
It amazes me that there are those that think that regular audio CD players
can't do something CDROM players on computers do on a daily basis.
-->Neil
Neil Bradley            In the land of the blind, the one eyed man is not
Synthcom Systems, Inc.  king - he's a prisoner.
ICQ #29402898
2002-11-06 by elhardt@att.net
Neil writes:
will make no difference.<<
I was thinking the same thing. A wobbly 1 or 0 is still a 1 or 0. Unless data
is being dropped or lost because of the wobble, there will be no sound
difference.
When CD's hit the market years ago, Computer Music Journal had an article
showing that the digital data affected listeners. People grew weaker and were
not able to lift as much weight when listening to a CD as opposed to a vinyl
record. How ridiculous, considering the CD output is filtered and appears as a
continuous analog signal at the output.
-Elhardt
them is
disc.
doesn`t
this
You just said it yourself, it doesn`t matter if it is buffered or
not,if it wasn`t read propeply to begin with.
Your average Consumer CD player has approx. 4000 errors per second. A
HiFi player cuts it down by about half. AudioPhile and Pro Gear
brings down the error count to below 1000.
Recover from what, the hit your portable CD or Automobile CD player
took to avoid skips. :) For Data CD`s it doesn`t matter as much, but
for audio, it matters a lot.
 If you have
it
Sorry, but this statement is wrong. please read the Article with the
attached Url`s
players
What amazes me, is Designers inventing New Formats, when they haven`t
figured how to make the most out of the one that is there now.
This is all tongue and cheek stuff, at the end of the day, the
question remains, does it sound good or not
RM
> -->Neil
is not
> ICQ #29402898
2002-11-06 by Mike Marsh
I disagree.  If *one* zero is interpreted as a one on a data CD, it
could screw up the whole program, if it's an executable.  Data CDs
are much less forgiving; with audio, our ear integrates.
I think.
Mike
--- In motm@y..., elhardt@a... wrote:
> Neil writes:
as much as
you have
it
Unless data
sound
> difference.
The problem is caused by the wobble, thereby creating an error. Since
you have lost the bit in question, you can not recover it. Now
imagine this process taking place about 2000 to 4000 times in one
second and tell me it doesn`t affect the outcome of the sound.
article
weaker and were
to a vinyl
> record.
Was that Qualitative or Quantative Research :)
Guys, please Read the articles with the URL`s .  They are really
informative and dispell a few myths. I will post another set of
links  about this stuff in another post.
RM
a
> -Elhardt
That means that, assuming each of those "errors" are single samples, that
10% of the audio is destroyed. That's plainly absurd.
> A
Flatly not true. I worked as a repair tech for a short stint on CD players
- many brands (Sony, Denon especially). Not too particularly high end,
either - roughly $200-$500 players - in 1988.
Part of the focus process for the laser was done through checking pulses
coming from the error correction circuitry. That is, one pulse = one block
had an error reading it off the disc. I'm sorry, but the standard
alignment and adjustment procedure required there be *NO* errors.
That, and a misread can allow the disc to spin back around for it to be
reread.
Audio == data on a CD. There is no difference. Data CDs cannot contain
errors, so it absolutely must be possible to read a CD with less than 4000
errors per second, otherwise no program or data files would survive.
Doesn't this strike you as completely irrational - that somehow $30 CDROM
drives *CAN* do perfect data transfers, yet a $150 CD player *CAN'T*?
> attached Url`s
Already did. While it may appear rational on the surface, it's completely
baseless and the description is so high level that it can be applied to
Listen, I spent several years listening to "audiophiles" rave about the
increased listening quality of CD sound rings and marking the edges of
their CDs to make them sound better. It's all provably false and anyone
with even the first level of understanding of how it works knows it's
completely laughable.
Anyway, attempting to steer the ship back on topic, I have heard others
say that MOTM gear sounds "digital". I've heard a few of the VCO samples -
they don't sound digital. Clean perhaps, but not digital.
-->Neil
ICQ #29402898
2002-11-06 by Craig Critchley
Both audio and data CDs contain some redundancy that allow correcting single
bit errors and detecting more serious errors.  Correcting a single bit error
should be undetectable audibly or in a data stream.  Data is also
distributed, to some extent, so that a dropout that would affect many bits
is spread out somewhat.
If an error more serious than that occurs, audio players will interpolate
between neighboring samples.  The distribution of the error means that the
interpolation will happen several times to single samples in different
places rather than having one audible pop several samples long.  For low
frequency signals interpolation is not too bad, of course it affects higher
frequencies more.
A data CD, obviously, cannot interpolate if the error-correction fails.  On
a computer, though, you can retry a read, which often works.  I'm not sure
if higher end CD players retry reads (if there's a buffer it would be
possible) but I expect consumer audio CD players don't.
                    ...Craig
To: <motm@yahoogroups.com>
Sent: Tuesday, November 05, 2002 8:53 PM
Subject: [motm] Re: digital source and its medium puzzle- the answer
> I think.
> Mike
2002-11-06 by Tim Walters
You most certainly can. A CD contains redundant data, with which it
performs error correction--just like every other digital information
storage device.
Unless your disc is severely damaged, none of those "4000" errors
gets to the DAC.
I suggest creating a CD and checking for errors yourself. I've done
this, and there aren't any.
Tim Walters : The Doubtful Palace : http://www.doubtfulpalace.com
2002-11-06 by ixqy@aol.com
In a message dated 11/5/02 10:59:47 PM Central Standard Time,
ringmod45@... writes:
 It's been 20 years since I've read about CD encoding technology, so can
someone correct me if I'm wrong here?
 I seem to remember reading that the data on a CD is duplicated once or
possibly twice on every disc. That way, is there is a loss of any data, the
error correction tells the laser to go to one of the extra tracks to recover
it. The chances of the same bits of data on both tracks being bad is very
slim, so this takes care of most of the errors.
 Also, I seem to remember that the laser pickup is on a transport that moves
up and down. There is a sensor and circuitry that determines how far away the
disc is from the laser at any given point in time. It then physically moves
the laser up and down to follow any movement of disc surface. This keeps the
laser in focus on the disc surface to avoid loss of data.
 When data cannot be recovered, error correction then kicks in to the phase
that Paul mentioned somewhere, and interpolates any lost data.
 For what it's worth, I used to work at a high end audio shop years ago. One
of the guys from McIntosh (I think it was) came in to talk to us about the
product line. To demonstate the integrity of the error correction on their CD
players, he attached thin strips of masking tape (drafter's tape?) to the
discs. He put them on one by one, radially across the surface of the CD. He
got up to something like 6 or 8 strips until it caused noticeable problems
with the music! This is pretty wild considering that each one of those strips
of tape was about 1/8" thick. Comparing that to the size of each bit on the
disc surface (forgot how many microns that is), you get an idea of how well
the error correction works. This was 15+ years ago, so I'd assume there have
even been more improvements since then.
 Andrew
2002-11-06 by jhaible
Yes. When I start downloading my maibox via modem, and I see
how many mails will be coming in, I can guess there must have been
a popular, off-topic thread in one of the mailing lists, even before
they arrive.
> I have heard others say that MOTM gear sounds "digital".
This comes from a single person (and a few of his fans) who
pretends he cannot hear the difference between a sample playback
machine and a free running VCO. This person obviously
used the word "digital" in order to say something nasty.
I've wasted way too much time in discussion with that guy.
There was a time when "digital" was used as a positive attribute
to advertise "low-noise", "modern", whatever. While this
word has a well-defined technical meaning (using numbers for
data representation - "digits" are "fingers", for counting in integer
steps ...), it's also just a _word_, and as such it follows every
fashion of the people who use it.
Personally, I'm happy that my MOTM is analogue, and I'm happy that
my VL7 physical modelling synth is digital. (But I'm thinking a lot about
analogue physical modelling modules lately - I guess I must discuss this
with Paul some time (;->) )
JH.
2002-11-06 by J. Larry Hendry
> From: jhaible <jhaible@...>
> Yes. When I start downloading my maibox via modem, and I see how many
mails will be coming in, I can guess there must have been a popular,
off-topic thread in one of the mailing lists, even before they arrive.
Hint hint
> (But I'm thinking a lot about analogue physical modelling modules lately -
I guess I must discuss this with Paul some time (;->) )
Oh yes. :)  Please do.
LH
