MOTM
FS: Last chance before auction: Ampex MX10, Minimoog, SDE330, Drawmer 1960 -- VINTAJ D00D, NOT ARP, NOT OEBERHEIM, etc ;)
2002-11-07 by media.nai@rcn.com
I've added some more gear and slashed prices.  I need to find a new home
for this stuff by December, and frankly the dumpster is starting to look
like a better alternative than that infernal auction site.  While I've
never actually met my garbage men since they come out here at 4 AM, they've
never given me any reason to think they are *ssholes.
So hear you go.  I'm taking pictures today so I will posting on
@#%&$ Eb*y tomorrow night!!
Please feel free to forward this email to other forums.
Ampex MX10                                         $950
All tube mic pre and four channel mixer.  Works perfectly.
I tested everything last night and I must be crazy to sell
this thing.  No really, it sounds better with dynamic mics
than any other pre-amp I've ever heard.  3U rackmount.
Fully transformer balanced for that truly vintage sound.
The stainless steel front panel is flawless.  Original knobs
and dial indicators. The pots and switches are smooth and quiet.
Except for the incredible build quality, it's hard to believe it
was made in 1963!! Includes tube shields and Faraday cage screen cover
(oddly enough, these were missing on most of the other units I've seen).
Includes two sets of tubes -- the ones I found in there,
and a set of noise tested Russian tubes and an NOS CBS "Hydron"
that is in there now.  I replaced the power cord.
Mini Moog Model D  w/Calzone flight case            $2175
Stunningly beautiful cosmetic condition.
Everything works perfectly.  Recently tuned and calibrated.
This is an early Mini with the original "phatter" oscillators.
All original knobs and switches.  Flawless graphics.
Contains modification designed by Bob Moog for 1V/Oct external control.
This mod uses a Switchcraft jack and high-quality C&K switch.
It's completely hidden from the front panel, and does not alter
the sound or synth circuitry in any way.
Includes custom Calzone ATA case, S-trigger cable,
and external gate to S-trigger converter.
Roland SDE-330                                       $245
True stereo digital delay using Roland Sound Scape 3-D technology.
Exceptionally warm clean sound.  Unique spatial animation.
One of the few DSP boxes that seems to be going up in price.
EXCELLENT FLANGER.  Includes pitch shift, non-linear, and reverse delay.
CV input. Balanced TRS connectors. MIDI control. Syncs to MIDI clock.
Includes original box, both manuals, and photocopy of SysEx spec.
Pearl Analog Delay AD-33                             $199
Japanese BBD pedal from the 80's -- considered rare.
Can switch between two sets of feedback and delay settings,
that, as well as bypass, can be controlled via sequencer,
gates, or drum triggers. Six knobs, two stomp switches,
three LED's, and four 1/4" jacks (three TS and one TRS).
A few scratches, works perfectly.
Drawmer 1960                                         $1150
Valve hybrid using 12AX7 tubes.  Near perfect cosmetic condition.
Very flavourful.  Sounds quite British.  Vintage character.
Combination instrument pre amp (with EQ), two channel mic pre,
and two-channel compressor with link, sidechain, and inserts.
Best revision -- later VCA's, with earlier tube amplifiers.
Switchable attack and release, with 3-way analogue meters.
Includes user and service manuals.
UREI 539  1/3 Octave Room EQ                         $230, pair
27 band graphic EQ with high and low pass filters.
Switchable.  Adjustable gain with LED indicators.
Beefy 2U professional unit with balanced barrier strips.
Worn cosmetic condition, but front panel looks fine.
Both units work perfectly.
Price is for a pair of two mono EQ's.
Beringer  SNR-2000                                   $189
Denoiser.  Analogue noise reduction that's incredibly effective
and easy to use.  This is the pro version, not the other one,
and imho, it's the only thing Behringer has ever made that doesn't suck.
Two channels with stereo link option.  Balanced with both TRS and XLR
connectors. Looks great, works prefectly.
Includes manual and original box.
I'd keep it, but I just don't want anything that says "Behringer" on it.
Niche ACM                                            $60
Eight channel MIDI controlled mutes and faders, or 8*1 mixer
Box, manual, flawless, serviced by the engineer who designed it.
TERMS: Prepay or Paypal, Buyer pays shipping.
       All prices U.S. dollars.
CONTACT:  media.nai@...
My ISP has changed my address:
media@... is now media.nai@...
media@... is media.nai@...
Please make a note of it, Thanks!! :)
doh!!
Sorry, I didn't mean to post that here.  I edited my previous posting, and
the list address was still in the header from the last time.
