MOTM
Prepare to drool
Prepare to drool
2002-12-04 by Paul Schreiber
Dave 'Moe' Bradley's uSeq mockup now on line:
www.synthech.com/new_stuff.html
If you don't see it, hit Refresh on your browser.
Paul S.
Re: [motm] Prepare to drool
Errr......
www.synthtech.com/new_stuff.html
Drool shorted out keyboard.
Paul S.
2002-12-04 by Sikorsky
awwwwwww!!!!!!!!!
i can't wait for this one...
but is the final midi connector going to be panel mount or purely pcb
mount..?
cheers
paul b
sheffield / uk
PCB mount with a supporting panel bracket.
Paul S.
To: "MOTM listserv" <motm@yahoogroups.com>
Sent: Wednesday, December 04, 2002 4:58 AM
Subject: Re: [motm] Prepare to drool
> awwwwwww!!!!!!!!!
> mount..?
> cheers
> paul b
> sheffield / uk
2002-12-04 by Robert van der Kamp
Paul, although I still haven't seen a real MOTM panel
myself, don't you think that inserting a midi plug in the
font panel will scratch the paint?
- Robert
No, it won't. This is the *same* connector that Encore and Kenton use in their products.
Paul S.
To: <motm@yahoogroups.com>
Sent: Wednesday, December 04, 2002 7:18 AM
> - Robert
Re: Prepare to drool
2002-12-04 by sydilaxe
Several big questions regarding the Useq.  1) Can you use the Gate inputs to
reverse the sequence?  2) Can these inputs also be used as a random step
function?   Can you use a trigger to step through the sequences?  For
example, you are playing sequence 1 and then send a pulse into one of the
gate inputs to move to sequence 2, 3, etc. etc.
Re: [motm] Re: Prepare to drool
Yes to *everything*. Please read the PDF design document there on the page. It explains all of
this.
Paul S.
2002-12-05 by alt-mode
Paul,
The uSeq sounds very interesting and I know I will get at least one!  The
question I have is why the limit of only 9 sequences of up to 99
steps?  The 99 steps seems reasonable but the 9 sequences seems a bit
limiting since this is a digital device.  9 sequences makes a long gig a
bit tight and certainly doesn't allow for more historical storage (and
there doesn't appear to be any way to dump the sequences via MIDI).  Is
this a limit of the EEPROM you are using?  Would Flash memory with a
battery cost about the same and provide lots more storage (MBytes instead
of KBytes)?
Don't get me wrong, I know there is lots you can do with a single sequence
on this module but the limit seems low compared to other pattern-like
sequencers.
	Eric
2002-12-05 by Paul Schreiber
It's a limit of the EEPROM. I wanted a sub $400 until and this is what I came up with.
Paul S.
To: "Paul Schreiber" <synth1@...>; "MOTM listserv" <motm@yahoogroups.com>
Sent: Wednesday, December 04, 2002 7:42 PM
> Paul,
> of KBytes)?
> sequencers.
> Eric
Err...sub-$400 "unit".....
Paul S.
