MOTM
uSeq vs older seqs
uSeq vs older seqs
2002-12-04 by Paul Schreiber
> I'm curious as to your logic behind the MicroSequencer.  Why produce a
> module like this one when one can use a MIDI sequencer to achieve the
> same?
Live performance! Leave that laptop at home.
> Are you going to be coming out with an analog step sequencer with
> lot of knobs for real-time control?
The uSeq HAS real-time control, as well as 4 CV inputs. What more control could you possibly
want? A 'traditional' type lets you control tempo, note and sequence length only as fast as your
hands allow. The uSeq has over 15 different controls modifications all at the SAME time, with
panel, MIDI or CV or any combination. At the SAME time. And it quantizes, supports microtuning,
syncs to MIDI clock, has 9 patterns of 99 steps.
Bah on the older style! Bah, I say!
Paul S.
Bah Bah black sheep
Re: uSeq vs older seqs
2002-12-04 by sydilaxe
After reading the PDF, I see that the uSeq can do all that I would like it to do
and MORE.   Although it is very different from traditional analog sequencers
(and IMO can't really replace them), I can see a very powerful interaction
between a tradition analog sequencer and the uSeq.   With the four inputs,
you could route the voltage outputs of a traditional sequencer and use it as a
"front end for the uSeq."   This would be a VERY powerful combination.  Great
design, Paul!
