MOTM
motm 800 EG - back to zero?
2002-12-21 by Eric Frampton
Is there a way to make the 800 return all they way to the start of the
envelope when retriggered, as opposed to re-triggering from whatever
point it's already at?
I'm using an Oakley midiDAC2 in Multiple Trigger mode, and until I can
figure out a better way, I'm basically just putting some playing space
between notes.
Duh...what am I missing?
thanx
eric
Re: [motm] motm 800 EG - back to zero?
2002-12-21 by media.nai@rcn.com
>between notes.
If the gate isn't dropped, it will re-trigger from its current voltage.
The most typical way to drop the gate is to lift one key before playing the
next key, which is the same thing as "just putting some playing space
between notes".
Also, if Release is set above zero, the envelope will still go on even
after the gate is dropped.
So I don't think you are missing anything.
